Analytical Integration Help for ∫r1-x*I0(alpha*r)dr | Tips and Techniques
  • Thread starter Thread starter sicjeff
    Integral
The integral ∫r^(1-x) * I0(alpha*r) dr is challenging due to the variable x, complicating the use of integration by parts and recursion formulas typically applicable for integer powers. Attempts to expand the integrand into a Taylor series have not yielded satisfactory results. The modified Bessel function I0 is central to the problem, and while there are known recursion relations for integer powers, they do not apply here due to the variable nature of x. Suggestions include treating x as a fixed parameter to simplify the integral using the defining differential equation of the Bessel function. Overall, the discussion highlights the complexity of integrating products of functions derived from different analyses.
sicjeff
I am having some difficulty figuring out how to do this integral analytically.
∫r1-x*I0(alpha*r)dr
I have attempted to do integration by parts, but am unable to find any recursion. This would be easy if x was not variable. Also, I have attempted just expanding this term into a Taylor series, but this is not resulting in satisfying results. Any thoughts on how I might approach this one?
tried: u= I0(alpha*r) and dv=r1-x
also tried: dv=r*I0(alpha*r) and u= r-x
What is I0? What difference does it make what x is if the integral is a dr integral?
Thanks for the response. I0 is the modified Bessel function of the 1st kind. If r was raised to an integer power, there is a well-known recursion formula. I cannot take advantage of that recursion, because there are only special instances where x will give me an integer value for the power of r.
Hmm..
Why is not "x" to be regarded as some fixed, arbitrary parameter??
Try to regard it as just that, and see if you, by means of integration by parts, can simplify your integral by the defining differential equation of the bessel function
If I had known what your problem really was I wouldn't have replied. Sorry but I don't have the time or inclination to delve into this one. Perhaps someone else will pick it up.
[Edit] After posting, I see Arildno already has. :smile:
arildno said:
Hmm..
I think maybe that is the problem. This is but one step in a Taylor Aris dispersion problem. I am unsure if I can even go back and change my differential equation into a more friendly form. Essentially, what I have presented here is a multiplication of two functions which each were obtained independently earlier in the analysis which I now need to integrate. Only one of these terms contained a Bessel function.
step 1:
u=r-x , du=-x*r-(x+1)dr, dv=r *I0(alpha*r) dr, v=r*I1(alpha*r)/alpha
r1-xI1(alpha*r)/alpha+x/alpha*int(r-xI1(alpha*r)dr)
step2:
u=r-x, du= -x*r-(x+1) dr, dv= I1(alpha*r)dr, v=I0(alpha*r)/alpha
r-xI0(alpha*r)/alpha+x/alpha*int(r-(x+1)I0(alpha*r)dr)
step3:
u=r-(x+2), du= -(x+2)r-(x+3)dr, dv=r*I0(alpha*r)dr, v=r*I1(alpha*r)
I'm not really getting anywhere here. This looks like an infinite series solution.
  • · Replies 16 ·
  • · Replies 19 ·
