Need help with volumes of spheres with holes.
The discussion centers on calculating the volume of napkin rings formed by drilling holes through spheres of different diameters using cylindrical shells. Participants explore the relationship between the radius of the sphere (R), the radius of the hole (r), and the height (h) of the napkin rings. The key equation derived from Pythagorean theorem is R² - r² = (h/2)², which establishes a definitive relationship between these variables. This equation is crucial for expressing the volume of the napkin rings in terms of height.
  • Understanding of Pythagorean theorem
  • Familiarity with integral calculus and volume calculations
  • Knowledge of cylindrical shells method for volume computation
  • Basic geometry concepts related to spheres and cylinders
  • Study the method of cylindrical shells for volume calculations
  • Learn how to apply Pythagorean theorem in three-dimensional geometry
  • Explore integral calculus techniques for finding volumes of solids of revolution
  • Investigate geometric relationships in spheres and cylinders
Students in geometry or calculus courses, educators teaching volume calculations, and anyone interested in applying mathematical concepts to real-world problems involving shapes and volumes.
timm3r
if you guys have trouble reading that, it says,
Suppose you make napkin rings by drilling holes with different diameters through two wooden balls (which also have different diameters). You discover that both napkin rings have the same height h, as shown in the figure.
a) Guess which ring has more wood in it.
b) Check your guess: use cylindrical shells to compute the volume of a napkin ring created by drilling a hole with radius r through the center of a sphere of radius R and express the answers in terms of h.
I know how to find the volume of this using discs, which the equation would be
integral[-R, R] sqrt[R^2 - X^2] - integral[-r, r] sqrt[R^2 - x^2]
i have no idea how to answer this in terms of h, can someone please help me put this in terms of h.
There is a pretty simple relation between h, the radius of the sphere, and the radius of the hole that follows from pythagoras' theorem.
so if we use the pythagoras theorem, 2r would be the relation between the radius of the hole, what would be the relation of the radius of the sphere?
timm3r,
Draw a triangle with one vertex at the center of the sphere, the 2nd at the top wall of the cylinder, and the 3rd straight down from the second so that it forms a 90 degree angle with the first two. What is the length of the 3 sides of the triangle? That should give you your relationship between R, r, and h.
im still stuck on this problem, can someone make it more dumby proof for me?
ok i still don't get it, this is what i did
i still don't see how there is a relation between the radius of the circles.
It's hard to make it any clearer. One side of that triangle you drew is h/2, one is the radius of the sphere, and one is the radius of the hole. It's a right triangle, so you can use pythagoras' law.
ok did you see my picture? so if we go back to the c^2=a^2+b^2, a would be h/2, b would be the radius of the the hole, and c would be the radius of the sphere right?
How about writing that in the terms you are given: If r is the radius of the hole and R is the radius of the sphere, then r^2+ (h/2)^2= R^2. Since h, and so h/2, is the same in both spheres, we have R^2- r^2 the same in both spheres.
  • · Replies 21 ·
