Help with Philips 1000/J/2000 357 Rp 16Khz Capacitor
  • Thread starter Thread starter Yaaks
The Philips 1000/J/2000 357 Rp 16Khz Capacitor's capacitance value is unclear, but it is likely related to a TV application. Users suggest checking Google or the Philips website for a datasheet to find the capacitance value. Measuring the capacitor with a digital voltmeter (DVM) that has a capacitance feature is also recommended. The "357 Rp" may refer to dielectric resistance, while the "16Khz" indicates it is rated for TV flyback circuits. Accurate measurement or further research is essential for identifying the correct specifications.
Yaaks
Need Some Help here!
I have a Philips 1000/J/2000 357 Rp 16Khz Capacitor, can anyone tell me what the capacitance value is? i believe its a TV capacitor..
I don't know what the frequency reference is about... Have you tried google to see if you get a hit? Or maybe the Philips website will get you to a datasheet that will give you the value from the part #.
You could also just measure it -- many DVMs have a capacitance measurement feature now. Or if you have a signal generator and a resistor...
First number should be the value.
Second voltage.
Not familiar with 357 Rp - perhaps dieletric resistance.
16Khz probably means rated for TV flyback circuit.
try to measure it using digital meter
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 32 ·
  • · Replies 0 ·
