2025 Award
- 17,116
- 10,627
The operating frequency of the resonator, would be as stable as the signal generator crystal, say 1:105, (which could be GPS locked if needed to 1:1012). The frequency would always be correct, only the phase could change, because the resonator is driven by the signal generator through the PA.Malamala said:Do you have an idea (or can you point me towards some readings) about how well a properly implemented feedback loop can keep the frequency of the setup stable (i.e. what changes in the resonant frequency should I expect in a given amount of time)?
If the peak of the resonator moved away from the signal generator frequency, the resonator continues at the signal generator frequency. The thing that changes with the tuning of the resonator, is the amplitude of the resonance. For a low-Q resonator that is not a problem, but for a high-Q resonator it could significantly reduce the amplitude of the voltage. By measuring the resonator phase shift deviation, the PLL would pull the resonator back onto the reference frequency, restoring the amplitude, with zero phase error.
When the PA is loosely coupled to the resonator, there will be a phase shift across the resistive coupling network. That occurs because the reactance of the resonator is no longer zero at the operating frequency. The task of the PLL is to recognise a non-zero phase shift, and to pull the resonator back to zero reactance.
