Need to demonstrate 44 Newtons of force
  • Level: High School
  • Thread starter Thread starter stephejo
    Force Newtons
6 replies · 6K views
stephejo
I hope someone can help me.
I am a medical doctor and need to have a standardized way to demonstrate the force needed to press on the front of the cricoid ring of the larynx (neck) in order to occlude the esophagus (Sellick's maneuver) with the patient lying supine... so the thumb and forefinger press on the front of the neck with 44N.
The studies specify 44 Newtons. How much is that. Looks to me like 10lbs or 4.5kg on earth.
Is there an easy model that I can make and pass around the lecture room to show what about 44N "feels like"??
Thanks.
Why not just get a 10 lb dumbbell? Or a 10 lb plate for a barbell set?
If you want to have fun, make a lever that requires 10 lbs of force to depress--then students can see just how hard they must push with thumb and forefinger.
It's been a long time since college physics... is a simple pulley the same as a lever? If I make a pulley with 10lb and pushing down the end of the pulley the same thing?
Thanks!
My first thought was to use some sort of top loading scale. Maybe like this.
Sure, that would work. (There are a zillion ways to go.)
Thanks!
Fixed pulley, yes. Fixed pulley does not change the force magnitude. Only direction.
