Need upgrade for computer to edit 4K video
7 replies · 3K views · last reply
leroyjenkens
I have a camera that can shoot in 4K video, but trying to edit the footage is very laggy and my computer won't export the footage in 4K. I'd like to upgrade the computer I have instead of buying a whole new one. But I'm not sure what exactly I need to upgrade and what to upgrade it to. My computer can take DDR2 memory, and I had spare DDR3 memory to put in there, but my computer doesn't recognize it for some reason. I also need a better video card, but I don't know what inexpensive video card is capable of editing 4K video and fitting inside the case of my computer. I don't want to order one and the thing is just too big for the case. I built a pre-made computer. This is it: https://support.hp.com/us-en/document/c02781693
So my questions are what are the cheapest video cards that I could buy, that will fit in my computer, be accepted by my computer, and that would allow me to edit 4K video. And if I also need more RAM, how do I know what type to buy? Because just knowing that it takes DDR3 apparently isn't enough.
Thank you.
I think you would be better served by looking for a new computer with the latest CPU, memory, video card... known to be a good video editing platform.
Some of the common issues are CPU is limited to types of memory that can be used, the OS might be limited to the kinds of video cards... You may run into power supply limitations and heat dissipation issues as well.
Many YouTubers publish videos on their setups and that could be a good place to start.
Every time, I've done this upgrade route I've been disappointed and eventually decided to buy a newer computer for the task at hand. In one case, the cool box I got to house my stuff had poor circulation and I ran into heating issues constantly as the more cards the hotter it gets and the airflow is more restricted.
Here's one such example from Youtube, I'm sure there are others:
Thank you very much, jedishrfu. I was kinda hoping for this kinda answer and not hoping for it at the same time. On one hand, buying a new computer is easy, and I've had my current one for quite a while. But on the other hand, it will probably be much more expensive than just replacing a couple of components. Helpful videos too. Thanks again.
That's hopefully true. But I fooled myself before buying components hoping for an inexpensive solution, but in the end, I needed a new computer anyhow. Buying components first and a new computer later is more expensive.
  • Sad
The reason is that if it takes DDR2, it takes DDR2, and if it takes DDR3 it takes DDR3. Furthermore, DDR3 won't physically fit in a DD2 socket (and vice versa).
DDR2 was used in 2003-2007 vintage computers. So you're trying to do modern work with a 15-year old machine.
I don't know where your HP fits in, as it is only (!) 9 years old and uses DDR3 and not DDR2. But that machine will not be able to fit a normal-sized video card. You need a new case. That means you need a new power supply. Many of those motherboards had proprietary power supplies, so you probably need a new motherboard, and that means a new CPU and memory. And video take a lot of space, which implies adding a big hard disk.
What parts from your existing PC are you planning on reusing again?
I think that you would do better to identify exactly the performance characteristics that you require, and then buy a used machine that meets them and preferably exceeds them, and is no more than 5 years old, from a 99%+ reliable seller on ebay.
