Negative Moment of Inertia from Atwood Machine Experiment?
The discussion revolves around an Atwood Machine Experiment involving two weights, where the original poster aims to validate a relationship involving mass difference, gravitational force, and moment of inertia. The experiment includes varying weights and measuring the acceleration of one mass as it descends.
  • The original poster attempts to analyze the relationship between the difference in weights and acceleration, expressing confusion over obtaining a negative moment of inertia. Participants question the dependent and independent variables in the analysis, suggesting that the variation in masses should be treated as the independent variable.
Participants are actively engaging in clarifying the relationships between variables and equations. Some have provided alternative formulations for the equations involved, while others have pointed out potential misunderstandings regarding the setup of the experiment and the interpretation of the data. The discussion is ongoing, with no clear consensus reached yet.
There is a noted lack of clarity regarding the starting height of the descending mass, which may affect the calculations of moment of inertia. The original poster acknowledges a misunderstanding about the height measurement, which could impact the results.
firefox
I'm currently completing an Atwood Machine Experiment with two 100g weights on either side of the pulley, with a variance in weight created by attaching dimes and pennies to either side of the weights. The point of the experiment is to validate:
(m1 – m2)g = (m1 + m2 + I/R2)
The experiment involved varying the weights between the sides and timing how long M1 takes to hit the ground from being dropped from a height where m2 is just hovering above the ground. This was my data.
http://puu.sh/nYt7k/cef6642fe9.png
n represents the number of dimes attached to the bottom of m2. As the number decreases, the dimes removed are added to the m1 side.
height from pulley to ground: 0.31m
pulley radius: 0.025m
m1g - T1 = m1 a
T2 - m2 g = m2 a
(T1-T2) R = Iα
From this system:
(m1 - m2)*g = (m1 + m2 + I/R2 )*a
To graph the results, we can use:
y= (m1-m2)g
mx = (m1 + m2 + I/R2 )*a
http://puu.sh/nYtGJ/5ebdb6e1a8.png
Trendline equation for (m1-m2)g vs a: y= 194.179672x + 47.74182125
Moment of Inertia was calculated using: slope = (m1 + m2 + I/R2 )
when solving for inertia by using the slope of the graph created by the a as the independent axis and (m1-m2)g as the dependent axis, I get a negative number. I'm quite lost at this point and I'm not sure how to proceed. It doesn't make sense to me that inertia is negative. Could this be because I'm not accounting for the fact that the y intercept isn't 0 in our combined inertia equation?
Thanks in advance for the help,
Firefox
firefox said:
(T1 T2) R = I
What are you trying to express with with equation?
Sorry about that, I'm not used to the formatting here yet!
It should read:
(T1-T2) R = Iα
What do you think your dependent and independent variables are for you data analysis?
I think (m1-m2)g is my dependent variable and my independent is a (acceleration).
But don't you vary the masses and measure the acceleration? that implies to me that the variation in the masses is the independent variable. An that is a problem since the equation not only depends on the difference of the masses but also on their sum which are independent of one another.
You make a good point, I'll admit, I didn't critically think about this point; I was following instructions from my lab manual. I've switched the variables around to see if it yields a different result, and alas, it seems I am still getting a negative inertia.
http://puu.sh/nYDQv/d35faf1af2.png
The equation that relates a to the difference is not linear. It should be of the form (I think)
a = g⋅Δ/(2M +I/R2 - Δ) Where Δ is the mass difference and M is the sum of the two masses which is kept constant so we have only one independent variable.
Oops Just noticed that a should = g⋅Δ/(2M +I/R2 + Δ)
I'm not quire sure how you arrived at that equation. Do you mind explaining further?
a the measured acceleration is the y- axis and Δ the difference in the masses of the weights is the x-axis. M is the sum of the two masses and is kept constant. You will be fitting a function of the form
y = gx/( k + x) where k= 2M + I/R2 : k clearly should be a positive number.
of course you just need to put in a value for a, Δ , and M to find I.
Is the pulley height that of the center of the pulley? The bottom? Something else?
You don't specify the starting height of the descending mass specifically. Can you clarify?
It seems to me that if your total distance for the mass movement was less than about 26 cm then your calculated moment of inertia value would be positive.
Wow ! Thank you! I've been staring at my data, and you have made realized this blunder. my h value is from the center of the pulley to the ground, which now I realize, is not the height in which the weight begins to fall from. Cheers! Mystery solved.
Also, thanks to gleem for the help as well!
I'm still quite new, is there a rep system where I can click for you guys?
I'm glad it worked out. I couldn't see any obvious issues with the mechanics of your analysis so it occurred to me to look for what might be missing in the data.
As for a "rep system", you can "like" individual posts, and once per year there's a member appreciation vote for various categories. There's also the Feedback and Announcements forum in the PF Lounge area where members can express their opinions on their experiences here at Physics Forums.
Good luck with your lab report!
  • · Replies 102 ·
9K
  • · Replies 97 ·
17K
10K
  • · Replies 29 ·
