Negative sign in hopping amplitude
The discussion centers on the significance of the negative sign in the hopping amplitude within the Hubbard model. It is clarified that this sign is not merely a convention; it has real physical implications, particularly in systems where neighboring atoms cannot be consistently numbered. The negative sign influences energy minimization, especially in models like azulene and when considering the delocalization of electrons. The choice of sign affects the energy characteristics of orbitals in tight-binding models, determining the minimum energy points in k-space. Overall, the negative sign plays a crucial role in the stability and behavior of quantum systems.
hbaromega
Might be a naive question.
In many places, specially in the Hubbard model, people use a minus sign before the tight-binding hopping amplitude. What does the negative sign signify for? Any special intention?
Thanks.
The hopping amplitude is something like \langle\phi_j| T_\mathrm{kin}|\phi_i\rangle, hence it's sign is well defined although there is a certain arbitrariness in the choice of the phase of the phi_i.
That's true. But there must be a meaning for keeping this minus sign. I have seen Hubbard's original paper. Surprisingly that paper does not have this minus sign!
If the sign is just a matter of convention, then why unnecessarily an extra minus was chosen as a convention?
Thanks.
No, it is not just a convention, it makes a real physical difference, at least in lattices where you cannot consistently number neighbouring atoms as 1 or 2. A simple example is azulene in the Hueckel model (which is basically the Hubbard model in quantum chemistry)
Sorry. Still not clear to me. What if I write
$t_{ij}$ instead of $-t_{ij}$ in the kinetic part of the Hubbard Hamiltonian?
Does it make any difference? If yes, then what difference?
@DrDu
Sorry, the latex didn't work! I guess, you could follow the notation.
And I think, the Huckel model and the tight-binding model are equivalent. Hopping from one site to other site is similar to hopping from one orbital to another orbital.
Consider the infinite U limit. Here the electrons are frozen at the lattice sites because the U prohibits double occupancy, even as a virtual state. Now if you tune U to a finite value then electrons start hopping in the process getting delocalized, thus lowering its energy.
The sign of t captures this lowering of energy.
P.S. : I can't seem to construct an argument as to why delocalization would lower the energy :(
At large U, t can be taken into account perturbationally. As t is non-diagonal, it can make a contribution beginning with second order which will be proportional to t^2/(-U). Hence it is negative (stabilizing) and does not depend on the sign of t.
However, when going around a ring with an odd number of atoms, the sign does matter in higher orders, e.g. for a ring of three atoms the you get a contribution t_12*t_23*t_31/(-U)^2. For simple orbitals, like hydrogen 1s, t is negative, typically, whence these terms lead to a stabilization.
Thanks.
The sign of t is significant. For example in tight binding model it determines where is the minimum energy orbital: at k=0 or at k=Pi/2
Let us for example consider polymer of atoms with s atomic valent orbital. It is evident,that k=0 (LCAO) orbital has minimum energy.
If we take polymer of atoms with p atomic orbital we get minimum energy orbital with |k|=Pi/2
LCAO: Linear Combination of Atomic Orbitals
I can recommend the book of Nobel Prize winner in chemistry:
Roald Hoffmann, Solids and surfaces: A Chemist's View of bonding in extended structures, 1988
pages: 4-9
16K
  • · Replies 16 ·
