What is the net charge on the Earth?
  • Context: Undergrad
  • Thread starter Thread starter CWatters
    Charge Earth Net
The discussion revolves around the net charge of the Earth, exploring the implications of cosmic rays and solar wind on Earth's charge state. Participants examine the balance of positive and negative charges, the role of the ionosphere, and mechanisms that might influence charge neutrality. The conversation includes theoretical considerations and speculative reasoning regarding atmospheric and cosmic interactions.
  • Some participants suggest that cosmic rays, primarily protons, contribute to Earth's charge state, questioning how this aligns with the overall neutrality of the Earth.
  • Others argue that the solar wind, composed of both protons and electrons, plays a significant role in charge dynamics, with the majority of protons being harder to deflect than electrons.
  • A participant notes that the positive charge of the ionosphere relative to the Earth's surface may be influenced more by atmospheric processes than by the solar wind.
  • There is speculation about whether charged particles enter or leave the Earth, particularly during auroras, and how this affects charge neutrality.
  • Some participants propose that if the Earth were to acquire a net charge, mechanisms such as the solar wind would likely neutralize it by attracting opposite charges and repelling like charges.
  • Concerns are raised about the potential for indefinite charge buildup if no mechanisms exist to restore neutrality.
  • One participant mentions the concept of Birkeland currents as a means of charge exchange between the solar wind, magnetosphere, and ionosphere.
  • There is a discussion about the role of sprites and lightning in the charge dynamics between the atmosphere and the ionosphere, with differing views on their significance.
  • Some participants assert that the Earth is negatively charged relative to the ionosphere, while others clarify that lightning tends to discharge rather than build up charge.
  • Clarifications are made regarding the definition of "Earth" in the original post, suggesting it includes the atmosphere in the context of charge discussions.
Participants express a range of views on the mechanisms affecting Earth's charge state, with no clear consensus on the net charge or the primary influences at play. Multiple competing perspectives remain, particularly regarding the roles of cosmic rays, solar wind, and atmospheric processes.
The discussion highlights various assumptions about charge dynamics, including the definitions of charge neutrality and the interactions between different atmospheric layers. Some claims depend on specific interpretations of atmospheric and cosmic phenomena, which are not universally agreed upon.
  • #31
Suppose we have a flashlight that runs on alkaline batteries. We can take the flashlight inside of a Faraday cage. We can charge the cage to -1000 volts relative to a ground wire. The flashlight should work as normal. Electricity flows between the "positive" and "negative" terminals. Relative to the ground wire the battery's positive terminal would be at -998.5 volts.
davenn said:
it's actually more common for discharges from negatively charged areas of a storm cloud to a positively charged area of the earth
Dave
Saying that "lightning usually travels from a negatively charged cloud to a positively charged ground" can be a correct statement. That makes a tree similar to the positive terminal of a battery. The same tree would have a different charge if measured against the ionosphere or interplanetary space.
Astronomy news on Phys.org
  • #33
Thread reopened. Some off topic posts have been deleted, and some off topic content has been removed from some other posts. Everyone please bear in mind that if you think another member's post violates the rules, you should report it, not start an argument about it in the thread.
  • #34
Baluncore said:
Thunder storms generate a net positive charge in their head, at the top, opposed by a net negative charge in the mid-lower part.
The bottom of the cloud is charged positive relative to the Earth's surface.
This seems a bit confusing. If thunderstorms generate net positive charge at the top and net negative charge lower down, wouldn't the bottom of the cloud be negatively charged?
  • #35
Think of capacitors in series. The plates are Earth surface, cloud base, top of cloud, ionosphere. |-+|-+|-+|
Back to the OP subject.
The ionosphere is a good conductor. It is a sphere with capacitance to the rest of outer space.
Charge distribution inside that outer conductive sphere are quite irrelevant to the external situation.
The Earth's conductive surface along with the atmosphere are on the inside, so not relevant to the external voltage.
  • #36
Just to confirm I was thinking about the Earth as a whole including the atmosphere.
However it occurs to me that I could ask the question about anybody that could absorb cosmic rays such as the recent visitor from outside the solar system. Before it became subject to the solar wind would it have built up a positive charge because most cosmic rays are positively charged?
  • #37
yes, this is correct, as stated in my references
from first paper
The rebounding droplets acquire a positive charge and are carried by the convective updraught towards the top of the cloud, while the hail pellets carrying a net negative charge fall towards cloud base.
page 9 of the second paper shows positive charge higher and negative charge lower in the storm
  • #38
But the same plate can't be both negatively and positively charged, at least not in an absolute sense. Are these charges relative? ("Relative" would mean, for example, that the cloud base is more positively charged than the Earth surface, but more negatively charged than the cloud top--but this by itself does not tell us whether any of these areas are negatively or positively charged in an absolute sense, i.e., excess or deficiency of electrons overall.)
  • #39
What visitor would that be ?
The cosmic rays reaching the Earth's surface may be mostly hydrogen nuclei, traveling fast and stripped of electrons. But we notice those energetic cosmic rays most because they have a significant mass relative to beta particles and there is a magnetic selection processes in their path to Earth.
Any body will sweep up slow electrons as well as being plastered with fast protons, we do not know the relative charge population statistics, or the capture cross-section, so we cannot be sure on which side of zero the net charge will fall. My assumption is that the electron gathering or repelling ability of a body traveling through outer space will be determined by it's present charge, so we can expect it to stabilise near neutral.
When examining the Earth–Ionosphere capacitor we see that the negative ground, relative to the positive ionosphere has a gradient that is self-regulating. That is evident because charges move in the atmosphere, as insulation it is on the edge of breakdown. Any change in potential gradient will change the circulating currents and so regulate the potential gradient.
The fact that the Earth's surface is negative relative to the ionosphere shows that the charge on the surface is not due to incident protons alone and that other more significant processes must be going on.
All things are relative. Three plates make two series capacitors. The middle conductive plate will form an equipotential. Some electrons on that plate will be attracted towards the surface on the more positive side, while being repelled away from the surface on the negative side, leaving some holes. So there will be a charge separation across that plate. That charge distribution is the displacement current that flowed when the capacitor was charged. Since the plate is a good conductor, (not a capacitor), there will be no voltage difference on the conductive middle plate.
Think of two electrolytic capacitors connected in series. Is the common terminal one or two conductors ?
  • #40
https://www.nasa.gov/feature/solar-system-s-first-interstellar-visitor-dazzles-scientists
Thanks.
  • #41
No, equal numbers of protons and electrons (esp., un-ionized atoms) are neutral by definition. Some things (about charges) are indeed relative, but not all.
  • #42
When the number of protons is in a 1:1 ratio relative to the number of electrons, the net charge will average zero.
The populations are quite unrelated. Some of my relatives are pedants too, relatively speaking.
  • #43
The net charge is defined by the difference, not the ratio. The OP asked about the net charge.
  • · Replies 58 ·
  • · Replies 0 ·
  • · Replies 21 ·
