Net force and Newton's laws of motion
The discussion focuses on calculating the net force acting on a barge being pulled by two horses, each exerting a force of 490 N at an angle of 19° to the centerline of the canal. The correct approach involves breaking down the forces into their x and y components using trigonometric functions. The y-components cancel each other out, leading to a net force calculation based solely on the x-components, which results in a final net force of approximately 926.61 N after proper summation and square root calculation.
  • Understanding of vector components in physics
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with Newton's laws of motion
  • Ability to perform basic algebraic calculations
  • Study vector addition and resolution of forces in physics
  • Learn about trigonometric identities and their applications in force calculations
  • Explore Newton's laws of motion in greater detail
  • Practice problems involving net force calculations with varying angles and magnitudes
Students studying physics, particularly those focusing on mechanics and force analysis, as well as educators looking for examples of net force calculations in real-world scenarios.
warrior2014
Net force and Newton's laws of motion!
A barge is hauled along a straight-line section of canal by two horses harnessed to tow ropes and walking along the tow paths on either side of the canal. Each horse pulls with a force of 490 N at an angle of 19° with the centerline of the canal. What is the net force on the barge?
Fx= F1x + F2x...
Fy= F1y + F2y...
Fnet
I broke it into components and got the following:
F1x= 490cos19
F2x=490cos19
F1y=490sin19
F2y=490sin19
I'm not too sure where to go from here. I think you add all the Fx components and Fy components, then square them and take the square root but when I tried that, I got it wrong, which was 980 N (and they do not give you the correct answer).
Any help will be appreciated!
You have to consider direction of the force as well as magnitude. Do F1y and F2y point in the same direction??
F1y points upwards and F2y points downwards. So then when you do the sum of Fy=0. Then I tried to find Fnet and got 30.44 N which is also incorrect. I don't know what I am doing wrong :S
Yes, the y forces cancel. But how you did you get 30.44N?? Just giving an answer makes it hard to guess what you did wrong.
since F1x= 490cos19 and F2x= 490cos19, I added them and got 926.61 so I squared this answer and then did the square root of it. what am I supposed to do exactly and why?
oh never mind. HUGE calculation error on my part. I got the correct answer :) thanks for your help!
33K
