Neutron interferomerty with Protons?
  • Thread starter Thread starter shunra
    Neutron Protons
Neutron interferometry has not been successfully demonstrated with protons or electrons due to their stronger interactions with matter, which complicates their passage through solid materials. While double-slit experiments with charged particles like electrons and protons are feasible, they face challenges in maintaining coherence due to significant incoherent interactions. Electron crystallography shows that coherence can be preserved with the right crystals, yet large-scale Mach-Zehnder interferometers for electrons remain elusive. The primary limitation is that protons and electrons are more suited for surface measurements, as their interactions prevent effective bulk probing. Overall, the differences in particle interactions fundamentally impact the feasibility of using protons and electrons in interferometry compared to neutrons.
shunra
I have been looking for experiments demonstrating neutron interferomerty with protons or electrons instead, and found non. Should there be any difference? I refer to experiments in which, for example, the Mach-Zehnder interferometer is cut from a single crystal.
If you do interferometry with protons or electrons, it is not neutron interferomerty.
Double-slit experiments with electrons and protons are possible. As they are charged, their interaction with matter is stronger, so it is tricky to send them through solid matter without significant incoherent interaction.
mfb wrote "...it is tricky to send [electrons and protons] through solid matter without significant incoherent interaction."
But electron crystalography is possible (Davisson got a Nobel for it) so it seems that, at least with the right choice of crystals, coherence is not lost in the interaction. Why, then, can't one make a large scale Mach-Zhender interferometer for electrons using those crystals as beam-splitters/reflectors, just as is done in the case of neutrons?
If you diffract electrons, it is not neutron diffraction, is it?
What you have been told here is correct - it is easier to get penetration into a material's bulk with neutrons than electrons. If you want to use electrons, it is difficult to probe beyond the surface.
Ok, so the beam-splitter must be much thiner in an electronic MZ interferometer (thin enough for the electrons to pass though) but as I said, this has been done before and there is no loss of coherence. I still believe that there are no large scale electronic/protonic MZ interferometers for another reason.
There are - and we keep telling you why. Protons and electrons interact with the bulk medium and as such are only suitable for surface measurements. Believe it or not - youir choice.
I am slowly going through the book 'What Is a Quantum Field Theory?' by Michel Talagrand. I came across the following quote: One does not" prove” the basic principles of Quantum Mechanics. The ultimate test for a model is the agreement of its predictions with experiments. Although it may seem trite, it does fit in with my modelling view of QM. The more I think about it, the more I believe it could be saying something quite profound. For example, precisely what is the justification of...
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 33 ·
