Why Is My Circuit Showing Higher Current Than Expected?
  • Context: Undergrad
  • Thread starter Thread starter driedupsharpie
    Current
The discussion centers on unexpected current readings in simple DC circuits, specifically when using a 10Ω resistor and various voltage sources. Users reported higher than expected current values, such as 1.1 amps at 10.75 volts, indicating potential inaccuracies in voltage, current, or resistance measurements. The consensus emphasizes the reliability of Ohm's Law as a fundamental principle in electronics, suggesting that inaccuracies in measurement tools or components are likely responsible for the discrepancies observed.
  • Understanding of Ohm's Law
  • Familiarity with basic circuit components (resistors, voltmeters, ammeters)
  • Knowledge of DC power sources
  • Experience with measuring instruments calibration
  • Investigate the calibration process for voltmeters and ammeters
  • Research the impact of resistor tolerance (1% vs. 0.1%) on circuit performance
  • Learn about common sources of error in electrical measurements
  • Explore advanced circuit analysis techniques beyond Ohm's Law
This discussion is beneficial for electronics students, hobbyists experimenting with basic circuits, and anyone troubleshooting measurement discrepancies in DC circuits.
driedupsharpie
My first post on the forums, go easy on me...
So I'm getting a feel for the new lab my college has and all of the equipment in it so I thought I'd set up some VERY simple circuits just to get used to some of the DC power sources (there are a few different ones).
No matter what I do though, the current always seems to be slightly HIGHER than the expected value coming from the given voltage and resistance.
For example: I'll set up V = 10v R = 10Ω and get values above the expected (slightly)
I'll hit 1 amp @ 9.8 volts
I hit 1.1 amps @ 10.75 volts
I hit 1.2 amps at 11.7 volts
Any idea what seems to be causing this simulated lower resistance?
driedupsharpie said:
No matter what I do though...
Including measuring the same setup with a different voltmeter and ammeter? And trying different 10 ohm resistors?
A 9.8 ohm resistor? Obviously the voltage, current, or resistance measurements are incorrect, or any combination of the three. Not that I'm really telling you anything you don't already know. :) Are there any lab standards, recently calibrated supplies or meters, 1% or 0.1% resistors. Is your lab near the Mystery Spot in Santa Cruz California?
driedupsharpie, Welcome to Physics Forums!
Both Nugatory and meBigGuy have offered good suggestions to explain your unexpected readings. My suggestion is this: When just starting out in electronics place your trust...all your trust...in Ohm's Law! It has held true in every single test ever performed with it so far. So, there is some inaccuracy in your setup: either the current reading, the voltage reading, or the resistance value is faulty. One of these is giving you "unexpected results".
Now, once you discover that Ohm's Law is reliable, you may continue onward to more complex circuits knowing that the fundamentals are totally under control. This is the foundation you rest on while ascending the complexity ladder of electronics.
Cheers, Bobbywhy
  • · Replies 105 ·
11K
  • · Replies 38 ·
  • · Replies 30 ·
