Newton-Raphson in Visual Basic 6
  • Thread starter Thread starter Benx
    Visual
17 replies · 17K views
Benx
Hello,
I am progamming in Visual Basic 6, need help to resolve equation using Newton-Raphson
method.
My program is running, but not properly!
Thank you.
Hi Ho!
I think you should specify your problem in detail first before we can help you.
What kind of problem do you have in resolving the equation? Parsing the equation? Or, what?
Eus
"[URL Benx, today is your lucky day[/URL]
basePARTICLE - that code is for SECANT method - and, please no offense, but that's some old code ...
I think what Benx needs right now is exactly what Eus suggested - provide better details of his problem - that way we might be able to offer better help.
Eus said:
Hi Ho!
Eus
Hello,
I do not found the same result as example given in the book, i don't know were is the
failure.
I think is better to see the code. or the algorithms "function and it's derivative".
Benx
So, why didn't you just post the code?
Eus
Eus
Ok,
I will attach a vbproject to this message.
Code:
Attribute VB_Name = "Module1"
 Public Function NewtonExact(Root As Double, TOL As Double, maxIter As Integer, params() As Double) As Integer
  Dim iter As Integer
  Dim diff As Double
  Do
    diff = MyFxMu(Root, params()) / MyDerivMu(Root, params())
    Root = Root - diff
    iter = iter + 1
  Loop While (iter <= maxIter) And (Abs(diff) > TOL)
  If Abs(diff) <= TOL Then
    NewtonExact = True
  Else
    NewtonExact = False
  End If
End Function
Function MyDerivMu(X As Double, params() As Double) As Double
    ' First Derivative f'(µ)
    term1 = params(0) / (params(3) - X)
    term2 = params(1) / (params(4) - X)
    term3 = params(2) / (params(5) - X)
    MyDerivMu = (2 / (params(3) - X)) * term1 * term1 + (2 / (params(4) - X)) * term2 * term2 + (2 / (params(5) - X)) * term3 * term3
End Function
Function MyFxMu(X As Double, params() As Double) As Double
     'Function f(µ)
MyFxMu = (term1 * term1 + term2 * term2 + term3 * term3) - 1
End Function
Hmm. I didn't see anything technically wrong.
Benx, what are the values for the parameters (ie, your array params) ?
Also, some question to think about:
1. Have you graphed this out to see the behavoir near the root?
2. Do you have a reasonably accurate initial quess to root?
3. Do the iterates ever come close to some of the params values (in which case, we may have trouble due to sinularities?
Newton-Raphson
Hello,
You can see algorithm, available in Text file of project.
So, I want to know if the algorithm is implemented properly.
Best regards
Benx
Newton-Raphson
values are available in procedure Sub NewtonExacte_Click() in form code.
params(0 to 5)
Best regards
Benx
Like I said, I didn't see anything technically wrong.
I did read the txt file, but the expressions for F and F' are not too clear (looks like the lack of proper use of parens). I can only assume you interpreted the function "F" correctly.
...values are available in procedure Sub NewtonExacte_Click() in form code.
params(0 to 5)...
OK then, as I suggested, plot this function out and you'll see that the root is not where you think it is.
In fact, this function (as you transcribed) is multi-valued and also has a series of three poles (quess where) and may be very ill-form for a Newton search.
Are you sure you interpreted the function "F" correctly?
In fact, your function (as stated) can be manipulated to a search of the zero of a cubic polynomial.
Thus, give the original problem statement a review and make sure you have the correct interpretation of the function "F"
Hi Ho!
Your mistake is in the first derivative of your function.
If
[tex] F(\mu)=\left ( \frac{b1}{a1-\mu} \right )^2 + \left ( \frac{b2}{a2-\mu} \right )^2 + \left ( \frac{b3}{a3-\mu} \right )^2 - 1[/tex]
Then
[tex] F'(\mu)=2\left ( \frac{b1}{a1-\mu}\right ) \left ( \frac{a1 - \mu + b1}{(a1 - \mu)^2} \right ) + 2\left ( \frac{b2}{a2-\mu}\right ) \left ( \frac{a2 - \mu + b2}{(a2 - \mu)^2} \right ) + 2\left ( \frac{b3}{a3-\mu}\right ) \left ( \frac{a3 - \mu + b3}{(a3 - \mu)^2} \right )[/tex]
Since the quotient rule states:
[tex] \left ( \frac{u}{v} \right )'=\frac{u'\ v - u\ v'}{v^2}[/tex]
If the initial guess is 0.0, the program should find the root, which is at x = 2.566477775, more or less at its 33th iteration.
Good luck!
Eus
I need to correct myself --<groan> as I analyzed the wrong F. In my computations, I forgot to square the indiviual terms of [itex]b_i / ({a_i-\mu})[/itex]. Sorry for the confusion.
However, once I correct F, I do see a root near zero (between -.24 and -.22), a large positive pole around 1, and another zero near 2.5 ( this probably being the root Eus discussed).
But, I don't agree with Eus's derivative. If we have a term such as
[tex]g(\mu) = \Large(\frac{b_1}{a_1-\mu}\Large)^2[/tex]
and if I let
[tex]v(\mu)=a_1-\mu[/tex]
then
[tex]g(v(\mu))=\big(\frac{b_1}{v}\big)^2=\Large(b_1v^{-1}\Large)^2=b_1^2 v^{-2}[/tex]
and
[tex]\frac{dg}{d\mu} = \frac{dg}{dv}\frac{dv}{d\mu}= -2\,b_1^2\,v^{-3}\,\frac{dv}{d\mu}= -2\,b_1^2\,v^{-3}\,(-1) = 2\Large(\frac{b_1}{v}\Large)^2\frac{1}{v}[/tex]
Thus, I don't think the derivative is wrong, unless I missing something (which I proved capable of doing many times).
Again, for the given function F and the given derivative, the procedure does converge in abot 5 iterations to the root near zero ( Root = -0.236799382041445 ) but not to the root stated in the problem statement.
Hi Ho!
Isn't that if
[tex] g(\mu)=\left ( \frac{b_{1}}{a_{1}-\mu} \right )^2[/tex]
and
[tex] v(\mu)=a_{1}-\mu[/tex]
then
[tex] g(v(\mu))=\left ( \frac{b_{1}}{a_{1}-v(\mu)} \right )^2[/tex]
[tex] g(v(\mu))=\left ( \frac{b_{1}}{a_{1}-(a_{1}-\mu)} \right )^2[/tex]
[tex] g(v(\mu))=\left ( \frac{b_{1}}{a_{1}-a_{1}+\mu} \right )^2[/tex]
[tex] g(v(\mu))=\left ( \frac{b_{1}}{\mu} \right )^2[/tex]
Eus
Hello,
There is no error on derivative function!
Newton-Raphson is not indicated for this case.
first we compute u_bound an l_bound:
//Get upper bound on mu
u_bound1 = a1-fabs(b1);
u_bound2 = a2-fabs(b2);
u_bound3 = a3-fabs(b3);
u_bound = u_bound1;
if (u_bound2 < u_bound) u_bound=u_bound2;
if (u_bound3 < u_bound) u_bound=u_bound3;
l_bound1 = a1-1.73205080757*fabs(b1);
//get lower bound on mu
l_bound2 = a2-1.73205080757*fabs(b2);
l_bound3 = a3-1.73205080757*fabs(b3);
l_bound = l_bound1;
if (l_bound2 < l_bound) l_bound = l_bound2;
if (l_bound3 < l_bound) l_bound = l_bound3;
Then we use rtsafe algorithm "it's combined Newton-bisection method".
at the third iteration we found:
µ=-0.000109354
wow ... that's real interesting. Using your values of params
Code:
 params(0) = -0.404279 'b1
  params(1) = -0.767506 'b2
  params(2) = -1.013014 'b3
  params(3) = 0.629811  'a1
  params(4) = 1.000785  'a2
  params(5) = 1.369404  'a3
and your definition of F(x)
Code:
     'Function f(µ)
End Function
... I am just not getting your results, either graphically or iteratively. I am getting, as stated before, x aprrox = -.236 both iteratively and graphically.
µ, is the smallest root of the sixth degree polynomial f(µ).
The general shape of the graph of this equation shows that the real roots will be
distributed as follows:
1 root < a1 < 2 (possible) roots < a2 < 2 (possible) roots < a3 < 1 root.
