Newton Raphson method (convergence problem)
  • Thread starter Thread starter KarAnw
    Method Newton
5 replies · 2K views
KarAnw
Hello, I am new in the field of FORTRAN. I started to write a code using Newton Raphson method. Below is the code of main program portion only. During my calculation, I have found that my results are not converging, Any help or advice will be highly appreciated in this case.
Thank you for the effort of helping in advance. Program Free_energy
Implicit None
Integer:: i,j,l,k
Double Precision Gmic,U,Phi
Double Precision s,Uderv,cc,DG0,cf,ctot1,
& Keff,Cagg,ctot,sum,Cagg1,cnew,
& Cagg2,cctot1,kapp,error,Csalt,Csalt1,
& cext
Double precision :: Nelec
Double precision :: Nwat
Double precision :: Nlig
ctot = 1D0
cf=ctot/2
cext = 0.01
sum=0.0
DG0 = -100.0
Do While(DG0.le.20)
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
Keff=dexp(-Gmic(Nelec,Nwat,Nlig)-Nelec*DG0)
Cagg=Keff*((cf)**Nlig)
Cagg1=sum+Nlig*Cagg
Cagg2=sum+(Nlig**2)*Cagg
enddo
enddo
enddo
ctot1=ctot-Cagg1
cctot1=ctot-Cagg2
cnew = cf-(ctot1/cctot1)
error = abs((cnew-cf)/cnew)
cf = cnew
write(72,*) cf, error
if(error.lt.1D-7) exit
Csalt1 = 0.0
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
Keff = dexp(-Gmic(Nelec,Nwat,Nlig))
Csalt = Csalt1+Keff*((cf)**Nlig)*Nelec
enddo
enddo
enddo
Kapp = Csalt/cext
write(70,*) DG0, -log(kapp)/2
write(72,*) cf, -log(kapp)/2
DG0 = DG0 + 0.1
enddo
First I would like to thank you both for the reply,
Since you have mentioned that increasing the iteration number may solve the problem, but my question is how can I do that?
Also in my code, the function has summation over an exponential series of the Gimc, I am afraid of that also because I think that summation is also not happening there properly.
Further, I made two changes in the expression of the derivative of my function (Cagg2) and the expression of Keff in my code. The rest of the code is unchangeable and almost like the previous one except that two lines. I ran this one and I find this plot (-log(Kapp)/2 vs DG0) attached with this reply. My aim was to calculate the "cf" which has also the negative values in the calculated results.
I would like to thank you again for the help. Any advice or direction in this case will become helpful to me in near future.
Note: For your interest, the new corrected version of the code (only the main program portion only) has been given below,
Program Free_Energy
Implicit None
Integer:: i,j,l,k
& cext
Double precision :: Nelec,kB,T
ctot = 1D0
cf=ctot/2
cext = 0.01
DG0 = -100.0
Do While(DG0.le.20)
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
Cagg1=sum+Nlig*Cagg
Cagg2=sum+(Nlig**2)*Keff*((cf)**(Nlig-1)) enddo
enddo
enddo
ctot1=ctot - Cagg1
cctot1=ctot - Cagg2
cf = cnew
write(74,*) cf,error
if(error<1D-7)exit
Csalt1 = 0.0
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
write(73,*) cf
enddo
enddo
enddo
Kapp = Csalt/cext
write(70,*) DG0, -log(Kapp)/2
write(72,*) cf, -log(Kapp)/2
DG0 = DG0 + 0.1
enddo
End
part of your issue is that for example you define Nwat as a double, then assign an integer to it, yes it theoretically works, but better programming style is
Nwat = double(j)
it makes a double out of the j so that it is j.00000000
Thank you for the reply, I will follow your suggestion and let you know about the result.
