Newton Raphson method (convergence problem)
  • Thread starter Thread starter KarAnw
    Method Newton
The discussion centers around a convergence problem encountered while implementing the Newton-Raphson method in FORTRAN for a computational model. Participants are exploring issues related to the code's structure, iteration limits, and potential errors in the mathematical formulation.
  • The original poster reports that their results are not converging and seeks assistance with their FORTRAN code.
  • One participant suggests that graphing the results of the iterations may provide insights into the convergence behavior.
  • Another participant advises increasing the number of iterations to potentially resolve the convergence issue.
  • The original poster expresses uncertainty about how to increase the iteration number and raises concerns about the summation over the exponential series in their code.
  • The original poster mentions making changes to the expressions for the derivative of their function and the expression for Keff, and shares a plot related to their results.
  • One participant points out a programming style issue regarding the assignment of integer values to double precision variables, suggesting a more explicit conversion method.
Participants do not reach a consensus on the specific cause of the convergence issue, and multiple competing views regarding potential solutions and code corrections remain present throughout the discussion.
There are unresolved concerns regarding the proper implementation of the summation in the code and the overall structure of the mathematical expressions used in the Newton-Raphson method.
KarAnw
Hello, I am new in the field of FORTRAN. I started to write a code using Newton Raphson method. Below is the code of main program portion only. During my calculation, I have found that my results are not converging, Any help or advice will be highly appreciated in this case.
Thank you for the effort of helping in advance. Program Free_energy
Implicit None
Integer:: i,j,l,k
Double Precision Gmic,U,Phi
Double Precision s,Uderv,cc,DG0,cf,ctot1,
& Keff,Cagg,ctot,sum,Cagg1,cnew,
& Cagg2,cctot1,kapp,error,Csalt,Csalt1,
& cext
Double precision :: Nelec
Double precision :: Nwat
Double precision :: Nlig
ctot = 1D0
cf=ctot/2
cext = 0.01
sum=0.0
DG0 = -100.0
Do While(DG0.le.20)
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
Keff=dexp(-Gmic(Nelec,Nwat,Nlig)-Nelec*DG0)
Cagg=Keff*((cf)**Nlig)
Cagg1=sum+Nlig*Cagg
Cagg2=sum+(Nlig**2)*Cagg
enddo
enddo
enddo
ctot1=ctot-Cagg1
cctot1=ctot-Cagg2
cnew = cf-(ctot1/cctot1)
error = abs((cnew-cf)/cnew)
cf = cnew
write(72,*) cf, error
if(error.lt.1D-7) exit
Csalt1 = 0.0
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
Keff = dexp(-Gmic(Nelec,Nwat,Nlig))
Csalt = Csalt1+Keff*((cf)**Nlig)*Nelec
enddo
enddo
enddo
Kapp = Csalt/cext
write(70,*) DG0, -log(kapp)/2
write(72,*) cf, -log(kapp)/2
DG0 = DG0 + 0.1
enddo
Technology news on Phys.org
I find that graphing the results of the iterations can be helpful.
Up the number of iterations and check for their convergence...it seems to me at first glance that you are not iterating enough.
First I would like to thank you both for the reply,
Since you have mentioned that increasing the iteration number may solve the problem, but my question is how can I do that?
Also in my code, the function has summation over an exponential series of the Gimc, I am afraid of that also because I think that summation is also not happening there properly.
Further, I made two changes in the expression of the derivative of my function (Cagg2) and the expression of Keff in my code. The rest of the code is unchangeable and almost like the previous one except that two lines. I ran this one and I find this plot (-log(Kapp)/2 vs DG0) attached with this reply. My aim was to calculate the "cf" which has also the negative values in the calculated results.
I would like to thank you again for the help. Any advice or direction in this case will become helpful to me in near future.
Note: For your interest, the new corrected version of the code (only the main program portion only) has been given below,
Program Free_Energy
Implicit None
Integer:: i,j,l,k
& cext
Double precision :: Nelec,kB,T
ctot = 1D0
cf=ctot/2
cext = 0.01
DG0 = -100.0
Do While(DG0.le.20)
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
Cagg1=sum+Nlig*Cagg
Cagg2=sum+(Nlig**2)*Keff*((cf)**(Nlig-1)) enddo
enddo
enddo
ctot1=ctot - Cagg1
cctot1=ctot - Cagg2
cf = cnew
write(74,*) cf,error
if(error<1D-7)exit
Csalt1 = 0.0
do i=0,2
do j=0,10
do l=0,10
Nelec=i
Nwat=j
Nlig=l
write(73,*) cf
enddo
enddo
enddo
Kapp = Csalt/cext
write(70,*) DG0, -log(Kapp)/2
write(72,*) cf, -log(Kapp)/2
DG0 = DG0 + 0.1
enddo
End
part of your issue is that for example you define Nwat as a double, then assign an integer to it, yes it theoretically works, but better programming style is
Nwat = double(j)
it makes a double out of the j so that it is j.00000000
Thank you for the reply, I will follow your suggestion and let you know about the result.
