Newton's 2nd - assumption or observation?
  • Thread starter Thread starter AJ Bentley
    Observation
The discussion centers on the nature of Newton's laws, particularly the distinction between observation and assumption. Participants argue that while Newton's first law is based on observable phenomena, the third law, which states that for every action there is an equal and opposite reaction, is more challenging to verify directly. Some claim that the third law is fundamentally unverifiable, while others provide examples, such as gravitational interactions, to demonstrate its validity. The conversation also touches on the philosophical aspects of scientific theories, emphasizing that science cannot prove absolute truths but can verify or falsify theories based on assumptions and observations. Ultimately, the debate highlights the complexities of understanding and testing foundational scientific principles.
AJ Bentley
For some reason, I've seen several recent questions that can be answered by simply pointing to Newton's 3rd law (Action and Reaction).
Then I stopped to think. The first law is observational. We've all seen enough (sort of) practical verifications of things not stopping or refusing to start. So I think we can say it's an observed fact about the universe.
But the 3rd seems to me to be fundamentally unverifiable. It's a sort-of err... fact.
Does that mean it has to be downgraded to an assumption?
Newton's first assumption.:devil:
Fundamentally unverifiable? Well, take two objects, one heavier than the other. Push them with the same force. Do you recognize a law here?
Then, change the force. Does it affect the motion somehow?
Action and reaction is Newton's 3rd. But I would say that Newton's laws are the postulates of Newtonian mechanics. As such, they are all assumptions whose logical conclusions are to be checked against experiment.
:redface: Ooops I meant 3rd of course.
(Always have trouble with names)
What I mean is, I can't see a way to check this one against experiment.
The nearest I can get is to say - put something between the jaws of a vice and squeeze it hard, then look to see if it moves.
But then you have to show that the two jaws of the vice are squeezing with equal force.
You see the dilemma?
Appealing to ignorance you could argue, when has Newton's 3rd law failed?
Newton's 3rd law is the conservation of momentum. It is pretty easy to check experimentally. Here is a typical Freshman-level physics lab experiment:
http://sdsu-physics.org/physics_lab/p182A_labs/indi_labs/Momentum.pdf
I don't know what you mean when you say Newtons 3rd law is unverifiable and unobservable, i can think of many examples in physics where two bodies are causing an equal and opposite force on each other. I shall show one of them below.
The Gravitational force between any two bodies (of anysize) is always equal. This means that the force the Earth has on an apple (causing it to fall) is equal to the force the apple has on the earth. This means that not only does the apple fall towards the Earth but the Earth also (very slightly) falls towards the apple.
Many various examples of Newtons 3rd law (like the one above) have been observed in space and fit perfectly into the laws of physics, this law is as verified and observable as any other of Newtons laws.
I would argue that c-of-m is a consequence of Newtons' law applied to movement.
Obviously, it's perfectly correct, and you can check anyone of it's consequences 'till the cows come home' . But the form in which Newton stated it interests me. He was apparently very good at spotting the blindingly obvious that no-one had seen before.
The observation that gravity acts downwards and not up, or sideways was another one.
Here, he's pointing out that when you push something it pushes back. (which ain't obvious if you haven't thought of it - remember all those ladder-against-a-wall problems?).
But as to directly proving it... He obviously left that small task to lesser minds.
Obviously. Isn't that what I just said? If you understand that then I don't get your previous comments about it being experimentally untestable.
I'm talking about an absolute and direct test of the actual statement of the law.
The other two laws can be verified directly - they are almost statements of an experimental procedure in themselves.
1/ Push something with a known force and measure the acceleration.
2/ Get something moving then keep observing the velocity.
But the 3rd - you can't directly measure the reaction independently of the action. You can measure all sorts of things that tell you it must be the same but the direct measure is impossible. You can't measure it because the 'acting' object is in the way and if you move it to get at the reaction, it vanishes!
You have the order backwards, but how do you know the force in your proposed experiments?
Ah well, that was the next question.
You have to invoke the 3rd law to measure it!PS I really don't give a *** for the names and numbers, you'll have to forgive me on that.
Exactly. So you cannot make an "absolute and direct" test of the "actual statement" of the first two laws either.
Understood, but it makes communication a little difficult.
The whole shaky edifice comes tumbling down... :biggrin:
No. You just have to understand what science does. First, you start with a theory which is a mathematical framework and a set of rules for relating the mathematical framework to the results of experiments. Then, you use the theory to make predictions about the results of experiments, run the experiments, and compare the results to the predictions. If the results of the experiments agree with the predicted then the theory is verified and if the results of the experiments disagree then the theory is falsified.
Often, a theory is inspired by some loosely stated physical principles, often called laws or postulates. The laws or postulates rarely if ever lead unambiguously to a theory. The laws or postulates cannot themselves be tested, only the experimental predictions of the theory. However, if the theory is verified then you have good reason to accept the loosely stated physical principles that inspired the theory (or are at least compatible with the theory).
The edifice is solid and well constructed, but many people misunderstand the architecture.
It was a joke .
AJ Bentley said:
you dingbat.
That is not very polite. But at least novop is amused.
No, I apologise. but at least I deleted it! o:)
I know it's hard to tell who you are talking to on this internet thingie and there's an awful lot of genuine idiots and schoolkids online but I kept hoping you would realize I'm not one of 'em.
Understood. Then please consider my post addressed to said students who might have misunderstood and thought there was actually a problem.
Sorry the entertainment is over so quickly novop.
Who says?
I didn't say there wasn't a problem.
But it's Ptolemaic. If action and reaction are taken to be equal then Newton's laws and all the rest follow.
But if they are not - and you can't prove they are, then you have situation where you have to reconstruct the entire system 'using epicycles'.
Heck - it's probably possible.
Fortunately Occam's razor comes to our aid. It isn't necessary to prove the law, only to accept it as the easiest and therefore correct.
AJ Bentley said:
Who says?
Then it wasn't a joke, after all. And my comments were, in fact, aimed at you.
Of course not. Science cannot "prove" anything. All it can do is verify or falsify theories. You really should go back and read my earlier post in detail.
Look's like the entertainment is back on novop.
Newtons third law is solely an observation. If you think about it, all laws in science can not possibly be laws, simply because humans do not know about even a fraction of the universe. Say we know about .0000001% of the universe. That means that 99.9999999% of the universe is unknown. This rather large section of the universe that we have no knowledge of may have a totally different structure. All of our physics would be null and void. I'm not saying that this is true, but it is definitely food for thought.
Well, it's past my bedtime but just very quickly:
I don't agree with you about creating a theory and then either justifying it or falsifying it by experiment.
IMO That's a very simplistic view and it assumes that there is only one truth.
It's a typically 17th Century viewpoint where God was held to be the Watchmaker and it was the Task of Science to Discover His Truths.
You must be aware that there is more than one way to present the mathematics of a system, each being no more or less 'correct' than another. For example in electromagnetism the B and E fields are used to describe nature and serve to explain electromagnetic radiation quite well. But these don't appear to have any connection with quantum mechanical ideas and in some aspects appear to be contradictory.
However, an alternative formalism using the concept of potential (in its four-vector form) arises naturally from quantum mechanical ideas and almost trivially solves such anomalies as the quantisation of the magnetic field - showing that it's an immediate consequence of the charge and spin state of the electron.
So, has Maxwell been falsified and the potential approach vindicated? of course not - both are completely valid views - one is rather more tractable than the other.
Maxwell was aware of the mathematics involved but he and his compatriots were unaware of certain facts so failed to find the easy route. It has been necessary to go right back and start again from a fresh position.
There are no absolute truths and it's only by questioning rigorously the very foundations of our assumptions that we can hope to avoid error.
Hi AJ, this whole "one truth" post is completely non-scientific. Science isn't about finding "absolute truths", and I certainly never assumed anything whatsoever about the number of truths. I don't know where this stuff is coming from.
As Dale said, all science can do is verify or falsify theories. Furthermore, you must make assumptions if you want a working theory. That these assumptions can't be proven is not an issue. And of course there are many ways of formulating and solving problems, did anyone claim otherwise?
I wish I'd never raised the point.
I just wanted to highlight the difference basically between an observable fact and an assumption.
I feel it's important somehow and wondered if anyone agreed. And to a large extent it was tongue-in-cheek.
Another example is something I referred to earlier, the Copernican view of the Universe is based on an assumption.
That the Earth goes round the sun is not a fact - it's an assumption. It just makes the arithmetic easier.
Assumptions are not something that's wrong (or right), they are the points at which alternative formalisms become possible - which makes them important.
Dale, surely that's a valid scientific principle?
If you can come up with a better theory and/ or falsify this one, you are more than welcome to do so. However, every time you try and you fail, the original theory will just get stronger. And you will probably make a fool of yourself.
Like has been said though, you will never prove anything. "Proof" is a mathematical concept, not a scientific one.
Lsos said:
If you can come up with a better theory...
You miss the point of my argument.
I am trying to make clear the distinction between physical observation of fact and the assumption of one.
Both are perfectly foundations for a valid theory. They differ in that each assumption gives rise to a set of valid alternative theories where an observation does not.
It is an observed fact that the sun moves across the sky. If you want to apply mathematics to that fact (a theoretical construction), you also need an assumption as to which is moving, the Earth or the sun.
The set of assumptions has two members. Both give rise to perfectly valid 'theories' of sun/earth movement. One is no more correct than the other. Under particular circumstances, one or the other is preferable.
My point is that assumptions are important 'turning points' on which real advances get made.
The Copernican view is a good example - it was based on challenging the very obvious assumption that the Earth was stationary.
I'm not advocating some crackpot theory. I'm trying to point out where the difference lies between crackpottery and logic.
Newton's third law isn't an observation, it's an assumption. I'm not suggesting I or anyone else should actually do something about it.
  • #31
I agree completely that there is a difference between observable facts and assumptions, but I don't think that the first and second laws are observable facts. They are also parts of the theory (or at least the inspiration for the theory) and the theory as a whole must be supported by observable facts.
As far as elements of a theory go, you can generally break the mathematical framework down into the assumptions, the definitions, and the derived implications (which is probably what you want to do here). I usually don't bother to break them apart that way except for historical reasons, since it is always possible to derive the same framework by rearranging which elements are considered assumed and which are considered defined or derived. But in any case, none of these theoretical elements are themselves observed facts.
  • #32
Yes.
Let's call it a day - I've been mauled.
