Newton's Laws Of motion Please Reply
11 replies · 7K views
chazgurl4life
This is my problem:
A window washer pulls herself upward using the bucket-pulley apparatus The mass of the person plus the bucket is 70 kg.
A) How hard must she pull downward to raise herself slowly at constant speed?...N
(b) If she increases this force by 9%, what will her acceleration be?
.....m/s2
I figured out part A) by taking 70 kg and multiplying it by 1/2 A which equals 4.9m/s2 and so the answer is 343 Newtons. But for part b i am confused as to how to use the the 9% and how to work it out..
9 percent of 343 is 30.47 N ..so if her new force net equal 374 N where should i go from there?.. I am sorry i just been working on this problem for a while and I am still stuck
isnt the net force =343+/-30.97?
the force pulling on the bucket and the girl is mg= mass x gravity (9.8 m/s2)...the normal force-the force she is pulling the pulley down is the only other force i can think of
Hang on a minute, why did you half the acceleration due to gravity?
Downwards force = [itex]70 \times -9.8 = -686N[/itex].
Therefore, the girl must be pulling 'up' with [itex]686N[/itex] to travel at a constant speed. However, if she pulls with an addition 9% of force then the upward force will be [itex]70 \times 9.8 \times 1.09 = 747.74N[/itex].
This means there is an unbalanced force of [itex]747.74-686 = 51.74N[/itex]. Using [itex]F = ma \Rightarrow a = \frac{F}{m} = \frac{51.74}{70} = 0.739 m\cdot s^{-2}[/itex]
i was confused on this same problem but i don't understand where the 1.09 comes from...?
1.09*x will give you the sum of the value of x plus 9% (0.09) of x
(instead of doing 9% of x, then adding to x)
ok i got it thanks so much!
