What does the scale read when two 100N weights are attached to a spring scale?
  • Thread starter Thread starter alex_the_seal
    Laws Newton's laws
The spring scale reads 100N when two 100N weights are attached, due to the principles of static equilibrium and Newton's third law. Each weight exerts a force of 100N, but since the system is in equilibrium, the scale measures the tension force, which is equal to the force exerted by one weight. This is analogous to a scenario where one end of the scale is fixed to a wall, demonstrating that the forces are equivalent in both situations.
  • Understanding of Newton's laws of motion, particularly Newton's third law
  • Knowledge of static equilibrium and force diagrams
  • Familiarity with the concept of tension in springs
  • Basic principles of force measurement using spring scales
  • Study the principles of static equilibrium in physics
  • Learn how to create and interpret force diagrams
  • Explore the mechanics of tension in springs and spring scales
  • Investigate real-world applications of Newton's laws of motion
Students studying physics, educators teaching concepts of force and equilibrium, and anyone interested in understanding the mechanics of spring scales and Newton's laws.
alex_the_seal
http://img131.imageshack.us/img131/2996/physicswb9.th.png
Two 100N weights are attached to a spring scale as shown. What does the scale read?
This concept is difficult for me to grasp. My natural instinct would suggest that the scale would read 200N, but I know this can't be right.
What I know (or think I know) is that the system is in static equilibrium with ΣF=0. The weight force of the block on the left is 100N, same for the block on the right. Now I notice that if I were to remove one of the blocks, say the left one, and tie the loose end to a wall, the solution becomes obvious, the scale would read 100N.
I know the answer is 100N. What I don't know is why the answer is 100N. There is a fundamental concept of Newton's laws that I am not getting here. Specifically Newton's third law. Can someone please explain this to me as if I were a 2 year old, with big colourful pictures preferably drawn in crayon?
First we have to make clear what the reading on the spring scale means. It means the current tension force in the spring scale.
So, I would say that the "reading" of the scale in this "situation" will be the same in the usual situation where one end of the scale is fixed on a wall. The two situations are equivalent, as you already proved in your analysis; each scale in each situation is in equilibrium.
Yes, the second block essentially 'replaces' the wall as far as forces are concerned. You can see this quite easily if you sketch a quick force diagram; The 100N the extra block exerts on the spring, is the same 100N which would be excerted by a wall, if the spring were attached to a wall.
For the spring scale to work, it ofcourse has to be in equilibrium (otherwise it would accalerate and won't measure the correct weight). A wall simply provides a reaction force equal to the weight exerted by the object to be measured.
(Another consequence of this is, that when you tie something to the wall and pull it, you can pull it just as hard as when you replace the wall with a second person who pulls as hard as you. If you understand this, you'll also understand the spring-scale problem)
Thank you, the solution is clear now.
  • · Replies 206 ·
