Newton's Third Law and Pulley system
In summary: N = aWe have solved for the acceleration of the bottom block. Now we need to solve for the top one.Equation for block 2 is F = M*AThe force for block 2 is 20N - tension - friction.The mass is 2 kg, the acceleration is the same for both blocks.20 - (tension) - (.3*2*9.8) = (2)*a19.7649 - (tension) = aSince the acceleration is the same, we can set the equations equal to each other.19.7649 - (tension)
StephenDoty
265
The lower block in the figure is pulled on by a rope with a tension force of 20 N. The coefficient of kinetic friction between the lower block and the surface is 0.30. The coefficient of kinetic friction between the lower block and the upper block is also 0.30. What is the acceleration of the 2.0 kg block??
Forces of A: T-(.3*1kg*9.8m/s/s)= (1kg)a
Forces on B: 20N - T- (.3 * 3kg * 9.8m/s/s)= (2kg)a
If you Add them together: 20N-(.9*9.8)-(.3*9.8) = 3a
20N-11.76 = 3a
8.24/3 = a = 2.74667m/s/s
Should it be 3kg as the mass used in finding the kinetic friction force in the formula for the forces on B or should it be 2kg? And should it be 2kg as the mass on the right side of the equation for the forces on B or should it be 3kg?
the answer of 2.75 is not correct. What am I doing wrong?
Thank you.
Stephen Doty
20N-11.76 = 3a
Thank you.
Stephen Doty
We can't see the picture yet. But it seems as if you are forgetting one force on the bottom block. If there is friction on the top block one wway, there must be the corresponding reaction force on th ebottom block acting the opposite way. So there are TWO friction forces on the bottom block. On friction due to the ground and one due to the top block
so do you add those two frictional forces
or do you subtract them since they are equal and opposite?
If you add them then would you please explain why you would not subtract them since they are equal and opposite?
Thank you
Be careful, forces that are action-reaction pairs NEVER ACT ON THE SAME OBJECT.
So the two frictions forces on the lower block are NOT part of an action reaction pair. One is due to the ground, the other is due to the top block.
Now, you have to figure out in what direction they are acting. The friction of th etop block on the bottom block will be opposite to the friction of the bottom block on the top block (these two do form a pair). I can't tell because I don't know if the friction force between the two blocks is static or kinetic (is the top block sliding against the bottom block or are they both accelerating as one object)? I need a better description of the situation
as the bottom block slides to the right the top box is sliding to the left.
Good.
You only counted the friction from the bottom surface. But the top block also exerts a friction force on the bottom block.
In finding the friction between any two surfaces, what counts is the normal force. Between the bottom block and the floor the normal force is the total weight of both masses = 3 kg. (But that's not the only friction force on the bottom block.)
The mass in F = ma is the mass of the object you are analyzing. For block B, it's the mass of block B = 2 kg.
So they are connected by a rope, so the acceleration for both is the same. That is, they have the same "a" value. So do a F = ma for block one, and do a F = ma for block 2, and solve for
"a" in each equation. Then maybe you could set them equal to each other? I'm working on this problem now, I'll let you know if it works.
Yes, they have the same magnitude of acceleration.
Yes, apply Newton's 2nd law to each block separately. Then you can solve them together to get the acceleration.
If you call the acceleration of the bottom block +a, what would be the acceleration of the top block?
BINGO! It worked. So to contribute:
"The lower block in the figure is pulled on by a rope with a tension force of 20 N. The coefficient of kinetic friction between the lower block and the surface is 0.30. The coefficient of kinetic friction between the lower block and the upper block is also 0.30.
Find the acceleration of the 2 kg block."
Equation for block 1 is F = M*A
The force for block 1 is Tension - (friction coefficent*mass*g)
the mass is 1 kg
the a is unknown, but we know that both blocks have the same acceleration, since they are connected.
So here is the final equation that describes the acceleration of block 1:
T-.3(1kg*9.8) =1kg*a
T-.3(9.8) = a (I just got rid of the 1kg, because 1 * anything is itself.)
now let's find an equation that describes the acceleration of block 2:
F = ma
20N - T -(.3*3kg*9.8 + .3(1kg*9.8) = 2kg*a
so:
a = {20N - T -(.3*3kg*9.8 + .3(1kg*9.8) } / 2
since a is the same for block a and b, set these two equations equal to each other, and solve for T.
this gives T = 4.706.
plug T back in one of the equations, and get a.
The first equation is easier to work with:
T - (.3*g) = a
4.706 -(2.94) = a
a = 1.766
this gave me the correct answer on mastering physics.
1. What is Newton's Third Law?
Newton's Third Law states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
2. How does Newton's Third Law apply to a pulley system?
In a pulley system, when one end of the rope is pulled down, the other end will move up. This is because the force applied to one end of the rope is transmitted through the pulley to the other end, resulting in an equal and opposite force that lifts the load.
3. Can a pulley system violate Newton's Third Law?
No, a pulley system cannot violate Newton's Third Law. The law states that forces always occur in pairs and are equal in magnitude and opposite in direction. In a pulley system, the force applied to lift the load is counteracted by the equal and opposite force exerted by the rope.
4. How does the number of pulleys affect the force required to lift a load?
According to Newton's Third Law, the force required to lift a load with a pulley system is equal to the weight of the load being lifted. However, the number of pulleys used can affect the direction of the force and the distance over which it is applied, making it easier to lift heavy loads with multiple pulleys.
5. Is a pulley system considered a simple machine?
Yes, a pulley system is considered a simple machine. It is a type of lever that uses a rope and a wheel to change the direction and magnitude of a force. By using multiple pulleys, the force needed to lift a load can be reduced, making it an important tool for lifting heavy objects.
