Newton's Third Law - Using pulleys and slopes
1 reply · 15K views
tastypotato
A 5.9 kg box is on a frictionless 40 degree slope and is connected via a massless string over a massless, frictionless pulley to a hanging 2.1 kg weight.
A.
What is the tension in the string if the 5.9 kg box is held in place, so that it cannot move?
B.
If the box is then released, which way will it move on the slope?
C.
What is the tension in the string once the box begins to move?
Fnet=m*a
A. The mass of the second box times the gravity will give me the solution to part A -> m2*(9.81)=20.61N
B. If the box is released then it will slide downwards on the slope because there is more mass in m1
C. This is where I'm stuck. My professor wrote down this equation for us to follow.
-m1*g*sin[tex]\theta[/tex]+T=m1(-a)
and
m2*g*T=m2(a)
but I don't know where to go from here.
Hi tastypotato! :smile:
(have a theta: θ :wink:)
B.
C.
Sorry, but that's the wrong reason … "more mass" doesn't clinch it … what matter is the equation your professor wrote down for you …
C. …
and
m2*g*T=m2(a)
(and btw, this is https://www.physicsforums.com/library.php?do=view_item&itemid=26", not third)
These two equations are the Ftotal = ma equations for m1 and m2 separately
(you have to do them separately) …
the first one is of the components in the direction of the slope, and the second is for the vertical components …
a is the same in both equations because the string has fixed length, so if m1 goes distance x up the slope, m2 goes distance vertically down …
so i] can you prove those two equations are correct?
ii] eliminate T, and find a :smile:
