Problem in Newton's third law and rope tension
10 replies · 5K views
tmn50
Hello hope you're doing well :smile:
I'm having a great problem understanding Newton's third law
let's say that we have 2 bodies with masses m1 & m2 where m1>m2
the 2 bodies are connected with a rope body1________body2----->F
a force F is applied on body 2 as shown below
friction is ignored
how does the 2 bodies move when the rope is massless and when it mass can't be ignored
there is none
according to Newton third law
when b2 aplies a force on the rope, the rope aplies a force on b2 so that it is equal to F in the opposite direction F2
and the rope aplies a force on b1 in the same direction as F let's call it F3
and b1 aplies a force on the rope equal to F in the oppsite direction let's call it f4
F4<---body1--->F3________<---F2 body2--->F
so there are 2 forces on B2 "F" and "F2" which are identical how will it move ?
body 1 has only 1 force acting on it "F3" so I guess it will move toward Body 2
also what's the diffrence when the rope has a mass and when it is massless
in short I'm stuck
Hi, Tmn50, and welcome to Physics Forums!:smile:
Before you move on to the rope with mass, you first need to clarify your understanding of Newton 3
friction is ignored
there is none
it is not equal to F
in short I'm stuck
You are confusing force pairs (per Newton3) which act on different objects, with net forces acting on the same object. You must draw a free body diagram of the system and of each block separately, identify the forces acting on them, and use Newton's laws. The system will be accelerating in the direction of the applied force F, where F is the only force acting on the 2-block system, and hence, is the net force acting on the system. Solve for the acceleration of the system using Newton 2.. Now move on to each block to identify the forces acting on them, and use Newton 2 to solve for the tension in the rope. The rope pulls on body 2 with a force F2, and that same rope pulls on body 1 with the same force F2 but in the opposite direction.
it is not equal to F it is not equal to F You are confusing force pairs (per Newton3) which act on different objects, with net forces acting on the same object. You must draw a free body diagram of the system and of each block separately, identify the forces acting on them, and use Newton's laws. The system will be accelerating in the direction of the applied force F, where F is the only force acting on the 2-block system, and hence, is the net force acting on the system. Solve for the acceleration of the system using Newton 2.. Now move on to each block to identify the forces acting on them, and use Newton 2 to solve for the tension in the rope. The rope pulls on body 2 with a force F2, and that same rope pulls on body 1 with the same force F2 but in the opposite direction.
Newton's third law state that if A aplies a force F on B than B aplies a force equal to F in magnitude and have an oposite direction
here A is B2 and b is the rope so why it isn't equal to F ??
You are mixing up your 'F's'. There is an applied force F acting to the right on block m2. If you draw a free body diagram of m2, you should see that in addition to the applied force F acting to the right on m2, there is also an internal tension force, T, in the rope, acting to the left on m2 (tension forces always pull away from the body on which they act). These are 2 separate forces, F and T, acting on the same object, m2. This has nothing at all to do with Newton 3. Applying Newton 2 to this block, then F_net = m2(a), or F - T = m2a. F is greater than T. Otherwise, the blocks could not accelerate.
Now draw a free body diagram of block m1. There is only 1 force acting on it, the rope tension acting to the right. For a massless rope, this tension force must equal T (since m1 pulls on m2 with a force T to the left, then m2 must pull on m1 with a force T to the right; this is Newton 3, force pairs acting on different objects.
Massless ropes serve to transmit forces from one object to another and the tension in such ropes are uniform throughout. This concept is sometimes confusing. It might be better to pretend that the blocks are connected by a small coupling (like a train) to get a better feel for Newton 3 .
When the rope has mass, the tension in the rope is not uniform, and the problem complexity deepens.
I'm a bit confused
So when we say a rope is massless it means it will only transfer force right ?
so if it has a mass the tension in it's points will be diffrent right ?
so if we directly apply Newton third law on this one B2 will apply a force on B1 and B1 will apply a force equal to Fb/a in the opposite direction right ?
i have one more question
F is applied on B2 and B1 is attached to B2 wouldn't this force affect B1 in the same way as it affects B2
thanks for your help ^_^
tmn50 said:
I'm a bit confused
Well this lettering is getting messy, see attachment and ask again. Don't get too hung up on Newton 3...it just says that if A exerts a force on B, then B exerts an equal and opposite force on A...think Newton 2.
http://img854.imageshack.us/i/rope.pdf/
exactly since the body exerts a force on the rope the rope should exert a force on the body right ?
and than the force exerted by the body on the rope should be equal to F cause there is no other source and there is no friction or anything to reduce it so now the body has two forces as you showed but why aren't they equal I mean what makes them diffrent please don't use Newton 2 law to explain it
Yes, correct, the body exerts a force on the rope, and the rope exerts an equal and opposite force on the body. This is Newton's third law. And that is all it says, it says nothing about the magnitude of the force. If you knew the force that the body exerts on the rope, you would know the force that the rope exerts on the body, but you don't know either force...yet
Unfortunately, one must use Newton 2 to explain it. We've already established that the blocks are accelerating, which means there must be a net force acting on the block. If the applied force F was equal to the rope force T, then the body would not accelerate.
There are 2 types of forces in Intro Physics...action at a distance forces, like gravity and magnetic forces, and contact forces (electromagnetic in nature), like applied forces, normal forces, tension forces, and friction forces. In this problem, the 2 contact forces on the 2nd block in the horizontal direction are the applied contact force, F, and the rope contact tension force, T2. F must be greater than T2 inorder for the block to accelerate.
Perhaps rather than looking at tension forces, consider instead 2 blocks, m1 on the left and m2 on the right, that are touching each other, resting on a frictionless table. A pushing force F is then applied to m2, acting to the left. Let's put some numbers on them, let m1 = 1 kg, m2 = 2 kg, and F = 9 N. Looking at the system of blocks, apply Newton 2,
F_net = Ma
9 = (1 + 2)a = 3a
a = 3 m/sec^2 to the left.
Now look at block 2 in a free body diagram. We have an applied force of 9 N acting left, and an unknown normal contact force, the force of block 1 on 2 (call it N), acting right. Apply Newton 2 again, and solve for the unknown normal force:
F_net = (m2)a
9 - N = 2(3) = 6
N = 3 N
Now look at block 1 in a free body diagram. From Newton's third law, the force of block 2 on block 1 must be equal and opposite to the force of block 1 on block 2, that is, 3 N acting left on block 1. That is the only force acting on block 1 in the horizontal direction. Thus, per Newton 2,
F_net = m1(a)
3 = (1)a
a = 3 N/m^2, which agrees with our original result (this serves as a check on your work).
The big thing to note is that the applied force on block 2, 9 Newtons, is NOT the same as the contact force of block 1 on block 2, which is only 3 Newtons.
Clear??
PhanthomJay said:
Yes, correct, the body exerts a force on the rope, and the rope exerts an equal and opposite force on the body. This is Newton's third law. And that is all it says, it says nothing about the magnitude of the force. If you knew the force that the body exerts on the rope, you would know the force that the rope exerts on the body, but you don't know either force...yet Unfortunately, one must use Newton 2 to explain it. We've already established that the blocks are accelerating, which means there must be a net force acting on the block. If the applied force F was equal to the rope force T, then the body would not accelerate.
F_net = Ma
9 = (1 + 2)a = 3a
F_net = (m2)a
9 - N = 2(3) = 6
N = 3 N
F_net = m1(a)
3 = (1)a
Clear??
yep very clear one more question why there is a diffrence in the force ?
is it because of inertia ?
Yes, inertial mass, its resistance to change in motion.
thanks man :biggrin:
