NMR: Why do "identical" protons not experience splitting?
Identical protons in the same chemical environment do not experience spin-spin splitting due to their identical nuclear properties, which results in the total spin becoming a good quantum number. This phenomenon occurs because the nuclei do not interact with each other in a way that affects the magnetic field they experience. As a result, while splitting is present, transitions between singlet and triplet states are absent, leading to equidistant triplet states without observable splitting. Understanding this principle is crucial for interpreting NMR spectra accurately.
  • Understanding of NMR (Nuclear Magnetic Resonance) spectroscopy
  • Familiarity with quantum mechanics principles related to spin
  • Knowledge of chemical environments and their effects on proton behavior
  • Basic grasp of magnetic fields and their interactions with nuclei
  • Study the principles of NMR spectroscopy in detail
  • Learn about quantum numbers and their significance in nuclear interactions
  • Explore the concept of chemical shifts in NMR and their implications
  • Investigate the differences between singlet and triplet states in NMR analysis
Chemists, NMR spectroscopists, and students studying physical chemistry who seek to deepen their understanding of proton interactions in NMR spectroscopy.
RKlintworth
Hey, I've been trying to figure out why a protons in identical environments will not undergo spin-spin splitting with one another.
From what I understand splitting of a signal for a proton is due to the nucleus of another nearby either opposing the external magnetic field or acting in the same direction as this field. yet identical protons even on the same carbon will not couple with one another regardless of their close proximity.
If anyone could shed some light on this process it would be greatly appreciated.
Thank you.
Chemistry news on Phys.org
They both see the same environment: one carbon atom they are bound to, and one hydrogen atom somewhere nearby, and some other components of the molecule. Where do you expect a difference between the two protons to come from?
I don't expect the signals to have different chemical shifts at all, I realize that they would resonate at the same frequency. What I am confused about is why the nuclei no longer interact. Why the nucleus of the one does not effect the magnetic field experienced by the other? Why would a difference in chemical environment suddenly allow for this interaction?
I would expect a small, but non-zero shift compared to "no hydrogen atom there", but that would give a free radical so I guess it's hard to observe that.
The point is that total spin becomes a good quantum number if both nuclei are identical. So there is no transition between singlet and triplet states, but only within the triplet, which are equidistant. So the splitting is still there, only the transitions are missing.
Okay thank you, That makes sense.
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
  • · Replies 0 ·
  • · Replies 24 ·
