No natural numbers that satisfy x^2 - y^2 = 2
The discussion centers on proving that there are no natural numbers x and y that satisfy the equation x² - y² = 2. Participants explored various approaches, including contradiction and factorization, ultimately concluding that the only natural numbers that could potentially satisfy the equation lead to contradictions. The factorization method (x-y)(x+y) = 2 was highlighted, revealing that the only pairs of natural numbers whose product is 2 do not yield valid solutions. The consensus is that no natural numbers exist that satisfy the equation.
  • Understanding of natural numbers and their properties
  • Familiarity with algebraic identities, specifically x² - y² = (x-y)(x+y)
  • Knowledge of proof techniques, including proof by contradiction
  • Basic experience with integer properties and parity (even and odd numbers)
  • Study the properties of natural numbers and their definitions
  • Learn about algebraic identities and their applications in proofs
  • Explore proof by contradiction techniques in mathematical reasoning
  • Investigate integer parity and its implications in algebraic equations
Mathematicians, students studying number theory, and anyone interested in algebraic proofs and the properties of natural numbers.
lisamane
I'm trying to prove that there are no natural numbers x and y that satisfy the equation x^2 - y^2 = 2.
I tried to solve it by contradiction and so I assume that x and y are rational numbers and both x and y can be written in the form (a/b) where it's in its simplest form and a and b are both integers and b isn't equal to zero.
Therefore let x = (a/b) and y = (c/d)
Therefore (a^2/b^2) - (c^2/d^2) = 2
Then multiply by (b^2)(d^2)
(a^2)(d^2) - (c^2)(b^2) = 2(b^2)(d^2)
I don't know how to go further from here or if I am even on the right track.
I'd say you are not on the right track because you are trying to do it for rational numbers and the question was about natural numbers. (Which are the ornery numbers 1, 2, 3, and you probably know others. :smile:)
I would think about the factored form (x-y)(x+y)=2.
"Ornery" numbers?
So using (x-y)(x+y) = 2 I thought of:
if x and y are equal then left hand side is equal to zero (contradiction)
if y is greater than x
I thought that the left hand side would always be negative but this won't be the case as say
x = -3 and y = 1 , then left hand side is equal to 8 which is not negative, so I can't really use this case.
Is this more on the correct track?
Sure. But if x and y are natural numbers then x>0 and y>0 and they are integers. If (x+y)>2 then why can't that work? So the only possibility would be x=1 and y=1. Does that work?
lisamane said:
x = -3 and y = 1
Let me say again I think you need to look up the definition of natural numbers, -3 isn't a natural number. http://en.wikipedia.org/wiki/Natural_number
I don't think you need to use the factorisation. To get 2 you need x>y and from there it is very simple.
HallsofIvy said:
"Ornery" numbers?
I have used them in many unpublished calculations. :smile:
Bah, I forgot that natural numbers aren't negative. Would you include zero as a natural?
So from (x-y)(x+y) = 2,
Case 1: ( x = y )
Left side = (0)(x.x) = 0 ≠ 2
Case 2: ( y > x )
Left side is negative integer multiplied by positive integer which is equal to a negative integer which ≠ 2
Case 3: ( x > y )
This is what I'm stuck on but I tried doing it like this.
When both x and y are less than or equal to 2:
y = 1, x = 2: Left side = (1)(3) = 3 ≠ 2
When both greater than 2:
then let x = p + 2 and y = q + 2
(p - q)(p + q + 4) = p.p - p.q + p.q - q.q + 4p + 4q
= p.p - q.q + 4(p+q)
I was trying to show that when they are both greater than two than the result will be greater than 2 but I don't know how to.
These are the only three possible cases?
Reread what Dick said in post 6. Think about the question he posed about when x+y>2.
I say again forget the factorisation.
Let y = x + a where a>1
Later, once you have got it for natural numbers you may well be able to state and prove something for a wider class of numbers - that is what Polya in 'How to Solve It' would recommend.
Case 1: ( x = y )
Case 2: ( y > x )
Case 3: ( x > y )
I'm sorry, I don't really know how to go about anyone's suggestions so continuing with Case 3 I thought since the last is p^2 - q^2 + 4(p+q) then from the equation p^2 - y^2 = 2 so the equation becomes 2 + 4(p + q) and therefore since all positive, all are greater than two unless p and q. Doesn't that work?
Except that when I use American expressions I have certainly heard they seem to be not understood :biggrin: it was in my mind all along to say 'Be a country girl!' meaning I think you are being unnecessarily complicated.
Taking 1 step of my last suggestion you really can't do anything with
(x + a)2 - x2 = 2 ?
(x + a)2 - x2 = 2 ?
Earlier you said let y = x + a which if you put in the equation it should be
x2 - (x + a)2 = 2
How did it come to (x + a)2 - x2 = 2 ?
A so I did, well I have done more than hint so you will have to supply what I should have said that will make it come to something like that, get the idea, nothing complicated. :smile:
As an alternative, I would show that it isn't true for any integers, and then
your statement would follow.
(The following method is not meant to be shorter than others already mentioned.)
You could prove by contradiction each of four cases to complete it:
1st \ case: \ \ \ \ x \ \ even, \ \ y \ \ even
2nd \ case: \ \ \ \ x \ \ even, \ \ y \ \ odd
3rd \ case: \ \ \ \ x \ \ odd, \ \ y \ \ even
4th \ case: \ \ \ \ x \ \ odd, \ \ y \ \ odd
For example, let m, n belong to the set of integers
For instance, the second case could be:
Then x = 2m and y = 2n + 1.
Substitute these into the original equation and see if
you can arrive at a contradiction.
Look at it this way: x^2 - y^2 = (x-y)(x+y), right? So suppose that x and y ARE two natural numbers whose product is 2, then we have (x-y)(x+y) = 2. There are only two natural numbers whose product is 2, namely the numbers 1 and 2.
So either (x-y) = 1 and (x+y) = 2 OR (x-y) = 2 and (x+y) = 1.
Solve both those systems for x and y to get a contradiction.
  • · Replies 22 ·
  • · Replies 18 ·
