Noise Floor/Device Temperature Problem
ashah99
Please see an attachment below.
Pn= 10*log10(kTB)
dBm = dBW - 30 [dB]
Hi everyone, I would like to get some help with the following problem. I'm not sure if my answer is feasible. Thanks.
Typeset problem statement reading: Noise Floor: An earth station dish antenna has a physical noise temperature of 100 K. In a receiver with 20 MHz bandwidth, you measure the total additive white Gaussian noise to be -100 dBm. Estimate the device temperature of the receiver's LNA.
My attempt at a solution:
I used the noise power equation: Pn= 10*log10(kTB) and converted the -100 dBm to dBW by subtracting 30 dB to get -130 dBW. Then I tried to find the overall system noise temperaure, T, and then I subtract the antenna temperature to find the temp of the LNA.
Pn= 10*log10(kTB) = Pn= 10*log10(k) + Pn= 10*log10(T) + Pn= 10*log10(B)
-130 dBW= 10*log10(1.38e-23 J/K) + 10*log10(T) + Pn= 10*log10(20e6 Hz)
10*log10(T) = -130 dBW - (-228.6 dB/J/K) - 73 dB/Hz = 25.6 dB/K
T = 10^(25.6/10) = 362.3 K
T_LNA = T - T_antenna = 262.3 K
This seems quite high for LNA device temperature. Could someone help to see if my work is right or if I'm totally off-track or misinterpreting the problem?
Why should the temperature of the dish introduce noise? It is a metal sheet with negligible resistance.
Actually 100K is very cold so I think they mean Antenna Noise Temperature, not physical temperature. I think your method is OK but have not checked the numbers.
My assumption was antenna noise temp as well. Would you kind as to check if I’m on the right path?
