How to Calculate Time with Varying Acceleration Toward the Moon?
  • Thread starter Thread starter simjor50
    Acceleration
The discussion focuses on calculating the time it takes for an object to fall to the Moon's surface from a distance of 2R, where R is the Moon's radius (1,740,000 meters). The object is dropped with an initial velocity of 0, resulting in a calculated impact velocity of 1,679 m/s. The challenge lies in determining the time of fall due to varying gravitational acceleration, which is derived from the conservation of energy principles. Participants suggest using integrals to express time as a function of velocity and displacement, emphasizing the need to isolate dt and integrate accordingly.
  • Understanding of gravitational acceleration and its variation with distance
  • Familiarity with conservation of energy principles in physics
  • Basic knowledge of calculus, particularly integration
  • Ability to manipulate equations of motion
  • Study the derivation of gravitational acceleration using Newton's law of gravitation
  • Learn how to apply conservation of energy to falling objects
  • Practice solving integrals related to motion under variable acceleration
  • Explore the relationship between velocity, displacement, and time in physics
Students studying physics, particularly those focusing on mechanics and gravitational motion, as well as educators looking for detailed examples of variable acceleration problems.
simjor50
A object is brought up to a distance of 2*R (R=moon radius) from the moon mass center and dropped. Starting velocity is 0.
Calculate the velocity the object has when hitting the moon surface.
Calculate the time it takes to reach the surface.
Radius R = 1740000m
Moon mass M = 7.35*10^22kg
gravitational acceleration, g=6.67*10^-11*M/R^2
Conservation of energy in gravitational field.
Using the laws of conservation of energy i have managed to calculate the speed when hitting the surface: 1679m/s
The problem now is finding the time it takes. Would have been easy if acceleration was constant, but it isn't!
I tried to calculate it as if acceleration was constant and got 2073seconds. This is probably somwhere near the correct answer, but still it's not 100% correct.
If i have done it right the acceleration varies like this:
http://img31.imageshack.us/img31/3249/grafjd.jpg
How can i calculate the time used when the acceleration varies with the distance from the moon?
Thanks for all help :)
Start out by writing the equation of motion for the falling mass. Try and find an integral to represent the time of the fall. You'll eventually see that you need to express r^2 in terms of v in order to compute the integral. (Conservation of energy makes this fairly easy!)
The integral is pretty tricky, so if allowed, you might want to use a table in order to do it.
What equations do i have to integrate? I have tried to use all equation of motion and integrate them and i always end up with an extreme high number.
Could you please try to explain this in more detail? I do not understand integrals very well..
in the Energy Conservation equation, solve for v ...
(like you already did before plugging in values).
Now, since v =dx/dt , we can write a formula for dt.
THAT's what they want you to integrate.
Okay, that helped me a bit further :)
I now have this:
http://img708.imageshack.us/img708/3463/formel.jpg
For v i inserted what i used to get the speed when hitting the surface. But what should be inserted for ds here?
I really appreciate you helping me here!
What's the total Mechanical Energy of this 1kg object?
you need the formula for v at an arbitrary location r
as it falls downward ... sqrt(2/m[E_i - PE(r)])
falling downward, ds is usually called -dr .
Don't plug in the numbers so soon! They muck everything up and make it far too messy to solve the integral.
Try and find the time as an integral over some function of the velocity.
Remember that: F=ma=m\frac{dv}{dt}
You may be able to find the time as a function of displacement, but it is much more simple to find the time as a function of velocity. I suggest that you try the latter.
Now i have v as a function of r:
http://img443.imageshack.us/img443/527/16674494.jpg
6.67*10^-11 is the gravitational constant
M is the moon mass
R is the moon radius
v(R) = 1679m/s so this is correct compared to the speed i found earlier.
What to do next? I am completely blank...
Do i need a function for "ds" too? Or can i just insert position "r".
Use the definition of acceleration a=\frac{dv}{dt} to isolate dt and then integrate in order to obtain t as a function of velocity (Which in turn gives you the time as a function of displacement just as well.
I think i got it now!
http://img9.imageshack.us/img9/9884/tidd.jpg
Does this look correct to you? :)
Anyone that can verify that this is done correctly? :)
  • · Replies 40 ·
  • · Replies 73 ·
