Non-homogenious second-order linear differential equations.
The discussion focuses on solving the non-homogeneous second-order linear differential equation y'' + y = sin(x) using the method of undetermined coefficients and variation of parameters. The general solution is derived as y = (c_1 - 1/2 x)cos(x) + c_2sin(x), which aligns with the book's answer after simplification. The participants also explore resonance frequencies in electric circuits governed by I''(t) + RI'(t) + I(t) = sin(ωt), leading to the conclusion that resonance occurs when R < √2 and the resonance frequency is 1/(2π√2).
  • Understanding of second-order linear differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of variation of parameters
  • Basic concepts of resonance in electrical circuits
  • Study the method of undetermined coefficients in detail
  • Research variation of parameters for solving differential equations
  • Learn about resonance frequency calculations in electrical circuits
  • Explore Apostol's volume 1 for additional context on differential equations
Students and educators in mathematics, particularly those studying differential equations, as well as electrical engineers focusing on circuit analysis and resonance phenomena.
zonk
20) Determine the general solution of y'' + y = sin(x).
We attempt to solve this equation by the method of undetermined constants.
So y = u(x)sin(x) (such a substitution should reduce R(x) to a polynomial with a u-differential equation with constant coefficients according to Apostol. )
We get, after differentiation and substitution:
u'' + 2cot(x)u = 1
However, this equation doesn't have constant coefficients like Apostol said the method would produce. So I need some help there.
Doing it the regular way with variation of parameters, we have:
y = c1sin(x) + c2cos(x) + y1
where y1 = t1(x)v1(x) + t2(x)v2(x) and
v1(x) = sin(x)
v2(x) = cos(x)
The wronskian of the two functions is -1.
After computing we get
t1 = \frac{1}{2} {sin}^2(x)
t2 = \frac{sin(2x)}{4} - \frac{1}{2}x
So the general solution is
y = sin(x) (c_1 + \frac{{sin}^2(x)}{2}) + cos(x) (c_2 + \frac{sin(2x)}{4} - \frac{1}{2}x)
But the book says the answer is:
y = (c_1 - \frac{1}{2}x)cos(x) + c_2{sin(x)}
Why do I keep getting extra terms?
Edit: Never mind the second question. My solution simplifies to the book's general solution. Tricky, but I see it.
Referred to a dover book on differential equations. Figured it out, but Apostol doesn't explain that method in the text, yet equations of that type are given in the excercises. Anyone who has Apostol volume 1 care to explain how we are supposed to solve equations of the form y'' - 3y = 2e2xsin(x) based solely on what Apostol shows?
I don't have a copy of Apostol but the method of undetermined coefficients is the same as the annihilator method, the latter of which takes all the guesswork out of it. Look at:
http://www.utdallas.edu/dept/abp/PDF_Files/DE_Folder/Annihilator_Method.pdf
and try it with your original equation.
I'm having a little trouble with the applications section too
(Section 8.19, problem 9)
The current I(t) at time t flowing in an electric circuit obeys the differential equation
Where R and ω are positive constants. The solution can be expressed in the form I(t) = f(t) + Asin(ωt + α) where f(t) → 0 as t → ∞, and A and α are constants depending on R and ω, with A>0. If there is a value of ω which makes A as large as possible, then ω/(2π) is called the resonance frequency of the circuit.
a) Find all resonance frequencies when R = 1.
b) Find all those values of R for which the circuit has resonance frequencies.
Attempt:
a) I(t) is of the form c1v1(t) + c2v2(t) + I1.
Solving for I1, using the method of undetermined coefficients, we get.
I1 = Bcos(ωt) + Csin(ωt) where B = \frac {-R\omega}{(1 - \omega^2)^2 + (R\omega)^2} and C = \frac {1 - \omega^2}{(1 - \omega^2)^2 + (R\omega)^2}.
Therefore A = \sqrt{B^2 +C^2} = \sqrt{\frac{1}{(1 - \omega^2)^2 + (R\omega)^2}}.
A is maximized when the denominator approches 0.
So, for R = 1, we need to solve (1 - \omega^2)^2 + \omega^2 = 0.
Expanding and rearranged, we get \omega^4 - \omega^2 + 1 = 0. But solving for ω2, we get complex number pairs and not a real pair. I know we have to take both roots of the real number(s) to solve for ω. And for all the real solutions, we have to divide by 2π. But there no real solutions, yet the book has one resonance frequency.
b) If you guys help me with (a) I can figure it out. We want an R such that we at least one real root.
Attempt:
No, you do not have to take "roots of the real numbers", if you solve for \omega^2 then to find \omega you have to take the square roots of those two solutions whether they are real or not.
And for all the real solutions, we have to divide by 2π. But there no real solutions, yet the book has one resonance frequency.<br /> <br /> b) If you guys help me with (a) I can figure it out. We want an R such that we at least one real root.[/QUOTE]<br /> No, you don&#039;t. <br /> The characteristic equation is \lambda^2+ R\lambda+ 1= 0 which has roots \lambda= \frac{-R\pm\sqrt{R^2- 4}}{2}<br /> which lead to solutions of the associated homogeneous equation of the form <br /> e^{-(R/2)x}\left(Ccos((\sqrt{R^2- 4}/2)x)+ Dsin(\sqrt{R^2- 4}/2)x)<br /> <br /> A particular solution of the entire equation will be of the form y= Asin(x)+ Bcos(x) <b>unless</b> there is already of solution to the associated homogeneous equation in which case you have to multiply by t: y= Ax sin(x)+ Bxcos(x). Here, that does not happen exactly but you will get resonance if the solutions come close- ifthe arguments of sine and cosine in the solution to the homogeneous equation are x- that is if <br /> \frac{\sqrt{R^2- 4}}{2}= 1
I solved for the four roots of omega, and they are all complex numbers of the form re(z) = +-sqrt(3)/2 and im(z)= +-1/2, but the soution for the frequency is 1/(2*pi*sqrt(2). Also for b, the solution is R < sqrt(2). I do not see how we get those answers from what we know.
I figured it out for anyone interested. Since omega never approches zero, we have to find the minimum of the denominator, using differential calculus.
For the first post...
My solution is (sorry for not using LaTeX):
y"+y=sinx
(D^2+1)y=sinx
let y=e^mx
(D^2+1)e^mx=0
(m^2+1)e^mx=0
f(m)=0
m^2+1=0
m^2=-1
m=+or-i
where i= sqr (-1)
yc= C1cosx+C2sinx
R(x)=sinx
m'=+or-i taken twice as a root
yp=Axcosx+Bxsinx
yp'=A(cosx-xsinx)+B(sinx+xcosx)
yp"=A(-xcosx-2sinx)+B(-xsinx+2cosx)
(D^2+1)yp=sinx
-Axcosx-2Asinx-Bxsinx+2Bcosx+Axcosx+Bxsinx=sinx
-2Asinx+2Bcosx=sinx
equating coefficients:
sinx: -2A=1
A=-1/2
cosx: 2B=0
B=0
sustitution in yp:
yp=-1/2xcosx
general solution is:
y=yc+yp
therefore:
y= C1cosx+C2sinx-1/2xcosx
simplifying
y= (C1-1/2x)cosx+C2sinx ans.
hope it helps.
you can also solve it by inspection:
if R(x)=sinx or R(x)=cosx
and bn=0
then (D^2-a^2)y=sinbx
yp=-sinbx/(a^2+b^2)
and
yp=-cosbx/(a^2+b^2) respectively.
this cuts down the very long solution.
  • · Replies 21 ·
  • · Replies 18 ·
