Non-hydrocarbon based instrument lubricants
  • Thread starter Thread starter Mgt3
    Instrument
The discussion centers on the search for non-hydrocarbon based lubricants suitable for use on instruments like micrometer threads. Participants explore the properties of various lubricants, their effectiveness, and the specific requirements for lubrication in precision instruments.
  • Some participants inquire about the existence of non-hydrocarbon lubricants that can adequately protect metal surfaces, particularly in micrometer threads.
  • Concerns are raised regarding the film strength of non-hydrocarbon lubricants, with some suggesting that many do not provide sufficient protection for metal-on-metal contact.
  • Graphite, molybdenum disulfide, and lead dust are mentioned as potential lubricants, with specific applications noted.
  • One participant questions the necessity of lubrication for micrometer threads, citing personal experience with a well-maintained instrument that requires no lubrication.
  • There is a suggestion to consider hexagonal boron nitride (BNh) as a lubricant, particularly in high-temperature or vacuum environments.
  • A cautionary tale is shared about the incompatibility of silicone grease with certain finishes on micrometers, leading to seizing of the threads.
Participants express differing views on the necessity and effectiveness of non-hydrocarbon lubricants for micrometer threads. Some argue that lubrication is not needed, while others advocate for exploring alternatives to hydrocarbons. The discussion remains unresolved regarding the best practices for lubrication in this context.
Participants highlight the importance of understanding the specific requirements for lubrication, including the forces on micrometer screws and the materials involved. There are mentions of marketing claims versus scientific principles in tribology, indicating a need for references to support various assertions.
Mgt3
TL;DR
Question about lubricants not made from hydrocarbons
Are there any non-hydrocarbon based lubricants that can be used on instruments like micrometer threads? I know silicone grease exists, but it doesn't have the film strength to protect the metal. Are hydrocarbons the only game in town?
You really should learn to use Google. Search for "non hydrocarbon lubricant" and you'll get 981,000 results
What unusual forces are there on the micrometer screw ?
What materials are the screws made from ?
Why are non-hydrocarbon lubricants required ?
Graphite.
Molybdenum disulfide.
Lead dust is used to lubricate bearings in closed vacuum systems.
I did, but I also came across the fact that many of these lubricants do not have adequate film strength for metal on metal contact. So I asked the question.
Mgt3 said:
I did
Then why did you ask
If you had already answered you own question
You're not reading what I said, which was, "but I also came across the fact that many of these lubricants do not have adequate film strength for metal on metal contact." The question is, while there are other lubricants, the information I have come across said many of these lubricants are not good for metal-on-metal contact because of the lack of film strength. Hence, I am asking which if any of these other lubricants could protect a micrometer screw.
That sounds like marketing to me. Where did you read it ?
Please provide us with a link or a reference.
There should be very little force on a micrometer screw thread.
The last thing you want is a thick lubrication film on the thread.
Read the manufacturers lubrication specifications.
Why is "non-hyrdrocarbon" critical here. Furthermore, I've never heard of anyone lubricating micrometer threads in the first place. I have a Starrett 1" mic that's at least 60 years old and requires no lubrication at all. Threads are ground and polished and have very little friction. I don't move it fast it enough to generate any wear.
Gun oil doesn't have any hydrocarbons? I think mine does, but I'll have to check tonight...
If you have critical instrumentation lubrication needs I would recommend these types.
https://www.krytox.com/en/products
Do not mix perfluoropolyether based lubes with a hydrocarbon-based grease.
How does metal-on-metal not wear?
Selected dissimilar metals that do not oxidise, high quality finish, without a load.
Tribology is a peer reviewed science, not marketing with misinformation.
@Mgt3 When are you going to provide the reference that claims hydrocarbon lubricants are not good for metal-on-metal contact ?
Mgt3 said:
Summary:: Question about lubricants not made from hydrocarbons
Consider also hexagonal boron nitrite, BNh .
BNh is a good lubricant for high temperatures, oxygen atmospheres, space or vacuum systems, or where electrical insulation is important. BNh replaces graphite which is conductive and oxidises.
https://en.wikipedia.org/wiki/Boron_nitride#Hexagonal_BN
A tip learned the hard way:
edit: Added phosphoric acid, 2 places & a footnote. /edit [/size]
The local college was selling off surplus used equipment where I found a 1"-to-2" micrometer with the 1.000" calibration standard for Zero setting.
I cleaned it up with phosphoric acid and it was good... Then I applied some Silicone Grease to the threads. That is when I found that the Satin finish on the micrometer, the phosphoric acid, and Silicone Grease are NOT compatible!
It seems that the Satin finish, along with any oxide layer on the threads, were completely removed, leaving a virgin, and active, metal surface. After a few turns of the spindle the threads seized solid.
A rather discouraging way to learn something new. :cry:
p.s. In a later discussion with a chemist friend, he mentioned a half-remembered reaction between phosphoric acid and silicone grease.
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 27 ·
