Halc
- 394
- TL;DR
- Exploring why some coordinate effects become physical effects and v-v relative non-inertial frames
This topic is not about the pinned pages, but I went to the dilation page on the FAQ and it seemed incomplete. https://www.physicsforums.com/threads/time-dilation-definition-what-is-time-dilation.763074/
A quick review since the page is locked
"Time dilation is the factor by which an inertial observer measures another observer's clock as going slow"
I would have said 'computes' since 'measures' implies a direct observation, and an incoming clock is measured to go fast. Some astronomers forget this and mistake a sufficiently fast incoming object as actually moving FTL instead of just appearing to.
Second comment is that part way in the font suddenly changes needlessly to something I cannot read below 200% magnification.
"Third: Gravitational time dilation is greater (the clock is slower) where gravity is stronger (and gravitational potential is higher)."
The bold part is wrong. Gravity is pretty weak on say Mercury, but clocks run slower there than on Earth because the potential is higher on Earth.
Even Sabine Hossenfelder seems to make this mistake when dilation is a function of gravitational strength and of acceleration in one of her you-tubes. She should know better.
I don't want to link it here, but ZdrZf4lQTSg gets to it.
If somebody cares, I can copy or link to my critique of that video on another forum, which is a lot quicker than watching the whole thing.
--- Feature presentation: ---
Time dilation is described as a coordinate effect (at least under SR, not necessarily with gravity), not a physical effect since it is frame dependent. Linear speed is relative, so there's no local experiment that can determine an absolute rest inertial frame.
But rotation changes everything. Absolute rotation can be locally determined, and the dilation and length contraction and such suddenly seem absolute, suggesting that these things are more than just coordinate effects.
One example is (relative to an inertial frame) a stationary circular track stuffed bumper-to-bumper with objects that travel along it. As the objects pick up speed, they contract and more objects can be fit in. This is length contraction due to motion and since more objects can be fit into the same space, there's at least something physical about it.
Now consider the same scenario from a rotating frame where the objects are stationary and it is the track spinning. In this case, it is the stationary objects that are contracted and the moving track that is not. Things seem backwards in this non-inertial frame.
Clocks (all stationary) run faster at the center and slower the further from the center you go. There is a limited distance beyond which it is not possible to be stationary. This is similar to gravitational time dilation. There is not gravity here, nor is there spacetime curvature, but there very much is a difference in potential between stationary clocks running at different rates.
Locally, we put an observer in one of the objects on the track. It seems to be at least an accelerating frame. Clocks objectively up high run faster than the ones near the floor. Tidal forces can be measured. Rotation is more difficult to detect, but a gyro constitutes a local test that will show it. Notice that I say local, but relativistic effects like the clock and the tide tests, while being within a box, are not technically local. An accelerometer is local, but is not a relativistic effect.
I also often see cited in twin paradox topics (great reference, eh?) that Einstein, in some lecture, used gravitational equations and EP to explain simultaneity changes with Earth as computed in the frame of an accelerating ship going to some distant star & back, and this seems wrong since the equivalence principle is a local principle and an accelerating object isn't local. A gravitational field is curved spacetime and the accelerating object/frame is not. That's an objective difference rendering the equations for one irrelevant to the other.
Am I wrong there? The proponents of the equivalence cite that it only works for a uniform gravitational field, but there cannot be such a thing under GR. There can be no infinite plane of matter, and while the field inside an off-center hollow in a planet may be uniform under Newtonian gravity, it isn't uniform under GR. Contradictions result if it was uniform.
