Undergrad Non-Relativistic Bethe-Bloch Calculation for Alpha Particle in Xenon"
  • Thread starter Thread starter CloudNine
    Calculation
The discussion revolves around a user struggling to plot the Bethe-Bloch function for alpha particles in xenon, noting that their output curve appears incorrect despite verifying parameters and units. They are generating a plot in MeV/cm but observe an unexpectedly sharp peak and a rapid drop to zero, which deviates from expected behavior. Participants suggest reviewing unit conversions and the ionization potential, emphasizing the importance of using appropriate units and considering logarithmic scaling for energy loss plots. Additionally, they mention that a peak should occur around 0.6 MeV, indicating potential issues with the calculations. The conversation highlights the complexity of the Bethe-Bloch equation and the need for careful attention to detail in computational physics.
CloudNine
Hi all,
I got an exercise to plot Bethe-Bloch function (ignore the "Compare..." part, it belongs to an exercise above), for alpha particle in Xenon. See the question below:
I've been struggling to get a plot that makes sense. I checked my parameters and the units a million times already, but couldn't find where the problem is. On paper, the units I'm left with, after all the conversions, are MeV/cm, which is exactly what I want. But again, I get a weird curve...
Here is the Matlab code I wrote:
Code:
E_dat=[ 0.001    0.002    0.003    0.003    0.004    0.005    0.006    0.007    0.008    0.009    0.010    0.013    0.015    0.018    0.020    0.023    0.025    0.028    0.030    0.035    0.040    0.045    0.050    0.055    0.060    0.065    0.070    0.075    0.080    0.085    0.090    0.095    0.100    0.125    0.150    0.175    0.200    0.225    0.250    0.275    0.300    0.350    0.400    0.450    0.500    0.550    0.600    0.650    0.700    0.750    0.800    0.850    0.900    0.950    1.000    1.250    1.500    1.750    2.000    2.250    2.500    2.750    3.000    3.500    4.000    4.500    5.000    5.500    5.544    6.000    6.500    7.000    7.500    8.000    8.500    9.000    9.500    10.000 ];%MeV
% Constants for Bethe-Bloch equation:
rho = 0.010592; % [g/cm^3] for Xenon in 2 bar and 25 C conditions
qe=1.602e-19; % C
me=9.109e-28; % g
NA=6.0226e23; % Avogadro constant, 1/mol
K=9e13; % K=1/4*pi*epsilon0 , units of N*cm^2/C^2
Z1=2;
malpha=6.646e-24; % g
v=sqrt(2*E_dat/malpha); % sqrt(MeV/g)
A=131.293; % g/mol
Z=54;
I=(16*Z^0.9)/1e6; % MeV
first=-rho*4*pi*NA;
second=((qe^4)*(K^2))/me;
third=((Z1^2)./(v.^2));
fourth=Z/A;
fifth=log((2*me*(v.^2))./I);
aaa=first*second*fourth;
bbb=third.*fifth;
dEdX_BB=aaa*bbb*3.9e21; % 3.9e21 is to convert from N^2*cm/MeV to MeV/cm
plot(E_dat,dEdX_BB)
xlabel('Alpha energy [MeV]')
ylabel('dE/dX [MeV/cm]')
title('Stopping power of non-relativistic analytical expression for alpha particle Xe')
I know that the peak shouldn't be that sharp, narrow, high (10^4!) and not that close to zero. Also, the dE/dx trend should be more moderate and to spread much more nicely, than this sharp drop to 0..
Would appreciate your thoughts!
Thanks.
You could include your plot here.
Alpha particles at 1 keV will have an extreme energy loss even in a gas.
Likes vanhees71 and jim mcnamara
Use a reasonable set of units! Newtons, cm, eV?
What value is the ionization potential?
Here's the plot:
I know it is not the right plot as the lecturer showed something similar in class and it looked differently...
There are a lot of variables in this formula. I changed all units so I can end up with MeV/cm. I suppose the problem is indeed relevant to the units, but, as I wrote, I can not find the mistake... hence this post.
The ionization potential is given in eV in the exercise so I turned it to MeV.
Would you mind going over the units and see if I messed up? I've reached to a dead-end...
There is a good reason the energy loss is usually plotted on a logarithmic scale.
Likes Astronuc and vanhees71
You are right. However, in this case (as I know what to expect), it should look just fine even on a regular scale.
The curve should look something like - one would have to multiply by atomic density
https://www-nds.iaea.org/stopping/stopping_201410/index.html
Also, not quite as it's alpha particles in air and graphite.
https://www.nist.gov/system/files/documents/2017/04/26/newstar.pdf (see figures A.10 and A.11 respectively), which are somewhat consistent with the plot above.
It would help to plot energy in a log-scale as others suggested.
There should be a peak in S(E) about 0.6 MeV, so something appears to be amiss.
FYI - http://www.srim.org/Citations/Cit 02-54.pdf - but it's not complete.
