Non-Uniform Circular Motion - Finding total acceleration
2 replies · 9K views · last reply
Defagment
Diagram of a sphere on a cord of length r swinging in a vertical circle about fixed point O, with angle θ measured from the downward vertical dashed line.
Code:
a(total) = sqrt( a(tangential)^2 + a(radial)^2 )
I wrote out equations for the forces in the radial and tangential directions:
Code:
F(radial)       = T - ( mg * cos(θ) )
F(tangential) = mg * sin(θ)
I used the equations to find acceleration in the radial and tangential direction (a = F/m):
Code:
a(radial)       = (T/m) - ( g * cos(θ) )
a(tangential) = g * sin(θ)
I plugged it into a(total) = sqrt( a(tangential)^2 + a(radial)^2 ):
Square root of (T/m - g cos(x))^2 + (g sin(x))^2, written as a plain expression.
which simplifies to:
Square root of g squared sin squared of x plus the quantity T over m minus g cos x, all squared.
My answer is incorrect and I'm not sure what I did wrong.
Any help would be appreciated.
is this some kind of online question bank where you have to submit the answer ?
i see that your solution seems to be correct... may be you need to further simplify the expression you got...these online physics problem banks can act stupid...
Newton
Your answer seems to be correct. I think you need to simplify the expression by using sin^2(x)+cos^2(x)=1. That may change the final expression, but otherwise, the answer is same.
