Nonlinear spring energy problem
The problem involves calculating the change in potential energy of a nonlinear spring described by the force equation F=40x-6x^2 when stretched by 2 meters from its equilibrium position.
  • Participants discuss the relationship between force and potential energy, with attempts to apply the formula for potential energy and integrate the force function.
Some participants have offered guidance on integrating the force function to find potential energy, while others are exploring the implications of the nonlinear nature of the spring's force. There is a recognition of the need to differentiate between linear and nonlinear spring equations.
Participants are grappling with the correct application of formulas for potential energy and the implications of the nonlinear force equation, indicating a potential misunderstanding of the relationship between force and energy in this context.
lzh
The stretch of a nonlinear spring by an amount x requires a force F given by:
F=40x-6x^2
where F is in Newtons and x is in meters.
What is the change in potential energy U when the spring is stretched 2m from its equilibrium position?
U=.5kx^2
= .5(kx)x
F=kx
F=40(2)-6(2)^2=80-24=56N
U=.5(56N)(2)=56J
Thats what I thought would work, but 56J is no the correct answer. What am I doing wrong?
F=-dU/dx
use this
So it'd be:
56N(2m)=-dU
dU=-112?
Am I not getting this?
F=40x-6x^2
U=.5kx^2
= .5(kx)x
F=kx
U=.5(56N)(2)=56J
The trick here is to recognize that F=40x-6x^2 which is not the same as F=kx.
Now U(x) = [tex]\int^x_0\,F(x) dx\,=\,\int^x_0\,kx\,dx[/tex]
http://hyperphysics.phy-astr.gsu.edu/hbase/pespr.html#pe2
http://hyperphysics.phy-astr.gsu.edu/hbase/pegrav.html#pe
Oh, I see!
Thanks, I got it!
f=-dU/dx
integrating both sides
20x^2 -2x^3=-U
put x=2
U=-64J
change would be 64...and work done would be 64 J
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 18 ·
