What is the equation of motion for a Nonlinear Vertical Spring at equilibrium?
The equation of motion for a nonlinear vertical spring at equilibrium is derived from the Duffing equation, indicating that the restoring force is proportional to z³. The potential energy associated with gravity is converted into spring potential energy, leading to the relationship kb³ = mg at equilibrium. The total energy of the system is expressed as 1/2 m(z-dot)² = -mgz + kz⁴/4, although no analytic expression for the period exists. The discussion concludes that further exploration may involve elliptic functions for solutions.
  • Understanding of the Duffing equation
  • Knowledge of conservation of energy principles
  • Familiarity with potential energy calculations in mechanical systems
  • Basic concepts of nonlinear dynamics
  • Research the Duffing equation and its applications in nonlinear mechanics
  • Study conservation of energy in oscillatory systems
  • Explore potential energy calculations for nonlinear springs
  • Investigate elliptic functions and their role in solving nonlinear differential equations
Students and professionals in physics, mechanical engineering, and applied mathematics who are studying nonlinear dynamics and oscillatory motion in mechanical systems.
Raging Dragon
Solved the problem.
Where do you get that the restoring force is proportional to z³? There is nothing in the problem statement to suggest that the spring is anything but a linear (force proportional to z) spring.
If the force IS given in the question as proportional to z^3, then you can find d by conservation of energy.
The equation of motion for the nonlinear spring is then a form of the Duffing equation, which has been (and still is being) studied in great detail - but AFAIK there is no analytic expression for the period. That suggests to me there is something wrong with the question, or your understanding of it.
Problem solved, don't need anymore help.
You can find "d" by energy conservation:
The potential energy associated to gravity has wholly been converted into spring potential energy at the extremum d.
At the equlibrium position, the spring is streched a distance b and the tension is mg, so kb^3 = mg.
If we let the PE = 0 at z = 0, the initial energy of the system (KE + PE) = 0.
At displacement z (positive upwards) the PE (gravity + spring) is mgz + kz^4/4
At the extremes of the oscillation the velocity is 0, so the KE = 0, and KE + PE = 0 (conservation of energy from the starting condition), so the PE = 0.
So at the extremes mgd + kd^4/4.
Sp d = 0 (duh - we knew that already) or d^3 = -4mg/k = -4b^3.
You can write down the equation of motion as total energy = constant, i.e. 1/2 m(z-dot)^2 = -mgz + kz^4/4. But how you solve that to get the period, I dunno. Maybe you can express the solution as an an elliptic function or something since there's something that looks like sqrt(a + bz^3) in there. I don't know if that's a sensible suggestion or not.
