Nonseparable Differential Equation
7 replies · 33K views · last reply
altcmdesc
I know that this differential equation is not separable, but is there a way to solve it?
dy/dx=y+x
I've tried a substitution of y=vx:
(dv/dx)x+v=x+vx
(dv/dx)x=x+vx-v
dv/dx=1+v-(v/x)
I'm stuck trying to rewrite that as a product of v and x.
Any help is appreciated!
Set u=y+x,
then you get:
du/dx=dy/dx+1,
whereby your diff.eq reads:
du/dx=1+u, which IS separable.
Alternatively, find an integrating factor to your diff.eq.
By using that method, my answer was: eˣ-x-1.
Correct?
Thanks!
Of course there are many methods to solve the above equations as they are a system of linear differential equations. The methods solved above are great for their simplicity but not so great in terms of generality.
Correct?
Thanks!
Why not check it out?
We have: y=e^x-x-1,
whereby:
dy/dx=e^x-1=(e^x-x-1)+x=y+x
so that is indeed A solution.
You still lack the general solution.
isn't the general solution, the same thing but with the constant not being defined?
if not then please clarify it for me.
Yes it is...but your solution was [itex]y=e^x-x-1[/itex] which is a particular solution. the general sol'n would be [itex]y=e^x-x-1+C[/itex]...C= a constant. Never forget the constant of integration.
The general solution is:
[tex]y(x)= A\cdot e^x -x- 1[/tex]
If you set A=1 then you get the particular solution of altcmdesc. However, the general solution is also obtained via the method of Arildno.
Nothing to do with adding a constant just like that, rock.freak667, you have to add it at the right place.
