Nonuniform Semicircle of Charge problem
  • Thread starter Thread starter littlebilly91
    Charge
11 replies · 15K views
littlebilly91
A non-uniformly charged semicircle of radius R=28.0 cm lies in the xy plane, centered at the origin, as shown. The charge density varies as the angle θ (in radians) according to λ = + 5.8 θ, where λ has units of μC/m.
(picture included)
What is the y - component of the electric field at the origin?
dE=[tex]\frac{dq}{4\pi\epsilon r^{2}}sin\theta[/tex]
where [tex]\epsilon[/tex] = 8.85*10^{-12}
[tex]\theta r = s[/tex]
[tex]\lambda=\frac{q}{s}[/tex]
First I derived [tex](5.8*10^{-6})\theta^{2} r=q[/tex]
and took the derivative [tex]2(5.8*10^{-6}) r \theta d\theta=dq[/tex]
substituted into equation 1
dE=[tex]\frac{2(5.8*10^{-6})}{4\pi\epsilon r}\theta sin(\theta)d\theta[/tex]
Integrated from 0 to pi.
E=[tex]\frac{(5.8*10^{-6})}{2\pi\epsilon r}\int\theta sin(\theta)d\theta[/tex]
The whole integral simplifies down to pi,which cancels out and leaves
E=[tex]\frac{(5.8*10^{-6})}{2\epsilon r}[/tex]
I am getting 1.17*10^{6} N/C for an answer, but it's not correct.
Thanks for the help in advance.
It's supposed to be [tex](5.8*10^{-6}/2)\theta^{2} r=q[/tex]. A less roundabout way of doing this is to note that dq=λ*dL and dL=Rd(theta), so dq=λRd(theta).
why is that? I'm not seeing where that 2 came from. Does the 2 come in before the derivative because it's only half a circle?
A better question would be how you got [tex](5.8*10^{-6})\theta^{2} r=q[/tex] in the first place. Didn't you use dq/dl=λ, dq=λ*dl=λ*R*dθ?
I used [tex]\theta r = L[/tex] and [tex]\lambda=\frac{q}{L}[/tex] to get [tex]\lambda=\frac{q}{\theta r}[/tex]. I substituted [tex]5.8\theta[/tex] for lambda and rearranged to solve for q. I didn't know how else to take the nonuniform charge into account.
Again, thanks for the help.
Lambda does not equal q/L because the charge density varies across the circle. Try using the method I described: dq=λ*dL and dL=Rd(theta), so dq=λRd(theta).
Okay, I understand why I was wrong before. Is it correct to go from dq=λRd(theta) to dq =5.8(theta)Rd(theta)?
E=[tex] \frac{(5.8*10^{-6})}{4\pi\epsilon r}\int sin(\theta)d\theta[/tex]
=>(skipping a few steps) =>
E=[tex] \frac{(5.8*10^{-6})}{4\pi\epsilon r}(2)[/tex]
I believe that would be correct.
And it should also be positive because it points towards the negative charge, right?
thanks so much for the help!
How did you get rid of the
[tex] (\theta) from \int (\theta)sin(\theta) to \int sin(\theta)<br /> [\tex][/tex]
