Normal Force of a Puck on a Sphere
The discussion centers on calculating the normal force exerted on a puck sliding down a frictionless sphere of radius R. The normal force is expressed as N = mg(2 - cosø), where ø is the angle from the vertical. The key insight is that the puck leaves the surface when the normal force reaches zero, which occurs at ø = arccos(2/3). The vertical height descended by the puck before leaving the sphere is one-third the radius of the sphere.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of centripetal acceleration and its application
  • Familiarity with trigonometric functions, specifically cosine and arcsine
  • Basic principles of energy conservation in physics
  • Study the derivation of centripetal acceleration in circular motion
  • Explore the application of energy conservation in dynamic systems
  • Learn about the implications of normal force in different physical scenarios
  • Investigate the effects of friction on motion along curved surfaces
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in the dynamics of objects in motion on curved surfaces.
Oijl
Consider a small frictionless puck perched at the top of a fixed sphere of radius R. If the puck is given a tiny nudge so that it begins to slide down, through what vertical height will it descend before it leaves the surface of the sphere?
I recognize that when the normal force on the puck exerted by the sphere is zero, the puck is no longer on the sphere. Therefore, I seek to express the normal force as a function of height, or of the angle measured down from the vertical, from which the height is easily calculated.
I can't find a way to write the normal force. What would the normal force be, at a point? Looking at a solution, someone wrote:
N = mgcosø + (mv^2)/R
where ø is the angle measured down from the vertical, so that it could also be written
N = (mgh + mv^2)/R
Where does this come from? I don't see the truth in this expression of the normal force.
Hi Oijl! :wink:
It comes from good ol' Newton's second law … F = ma … in the radial direction.
So long as the puck remains on the sphere, the radial acceleration is obviously the standard centripetal acceleration (that's just geometry).
So put all the forces on the LHS (that'll be N and the radial component of mg), and m times centripetal acceleration on the RHS. :smile:
Hey, that makes perfect sense! Thanks.
BUT, oh no! When I solve for N, using mgR = (1/2)mv^2 + mgRcosø (which is E = T + U) to replace mv^2 in the equation with N, I get
N = mg(2-cosø)
So N = 0 when cosø = 2, which doesn't happen.
I have access to the solution, and the way they do it, they get down to N = mg(2-cosø) as well, but the next line they have written that, for mg(2-cosø)=0,
ø = arccos(1/2)
How can this be? It's algebra that I must be doing wrong, I believe, although for my life I cannot see it.
Hi Oijl! :smile:
(just got up :zzz: …)
ø = arccos(1/2)
(try using the X2 tag just above the Reply box :wink:)
mv2 = 2mg(1 - cosø) is right, but "the solution" is wrong.
You didn't do the F = ma that I suggested, with forces on one side and centripetal acceleration on the other.
As a result, you got a minus sign in the wrong place (and so, presumably, did "the solution").
This is a fundamental mistake that people keep making, they treat centripetal acceleration as if it was a force, so they get it on the wrong side. :rolleyes:
Try again, and this time write it all out properly! :smile:
F = ma
a = -(v^2)/R
F = N - mgcosø...?
Is that the radial component of the weight, mgcosø?
If it is, then, using
N - mgcosø = -((v^2)m)/R,
I get an answer that N = 0 when ø = arccos(2/3).
Well, you know, I got it anyway. I used a differently-defined angle, it was easier to see what the radial component of the weight was if I measured the angle up from the horizontal. Difference was I used sin instead of cos.
I got an answer of one-third the radius of the sphere for being the vertical distance through which the puck descends before it leaves the surface of the sphere.
Thank you for your help.
I think you were right the first time Oijl--angle=arccos(2/3)
  • · Replies 24 ·
  • · Replies 97 ·
  • · Replies 35 ·
