Normal force on scale in elevator at constant speed and with acceleration
  • Thread starter Thread starter BuBbLeS01
    Elevator
23 replies · 8K views · last reply
BuBbLeS01
A 56.0 kg girl weighs herself by standing on a scale in an elevator. What is the force exerted by the scale when the elevator is descending at a constant speed of 10 m/s?
What is the force exerted by the scale if the elevator is accelerating downward with an acceleration of 2.4 m/s2?
If the elevator's descending speed is measured at 10 m/s at a given point, but its speed is decreasing by 2.4 m/s2, what is the force exerted by the scale?
Fnet=ma
How do we find acceleration without having a time?
In all cases you are given the acceleration (or all the information needed to figure it out). You don't need the time.
Fnet=ma
Draw a free body diagram and then apply [tex]\sum F_y = m a_y[/tex]. That is all there is to it, really. Just be careful to include the correct sign of [tex]a_y[/tex].
Now for the first part I am not sure what to do with the speed??
All you care about is acceleration.
Reread the statement of the first problem. How is the velocity changing?
BuBbLeS01 said:
it's descending at 10 m/s
Acceleration is the rate of change of velocity. How is the velocity changing? (Hint: Read it carefully. :wink:)
BuBbLeS01 said:
it's not its constant
Exactly! So what is the acceleration?
BuBbLeS01 said:
ohhh so the only force acting is the weight.
No. If the only force acting on her was her weight, the girl would be in free fall.
so how is the third part any different from the second if the acceleration is the same?
The accelerations are not the same. Direction counts!
BuBbLeS01 said:
but they are both going down?
No. The second one has acceleration going down (it tells you that), but the third one you have to figure out the direction of acceleration by reading carefully.
ok so since the speed is decreasing then the force is acting to slow it down and bring the elevator eventually to a stop?
Sure. And which way must it be accelerating, since it happens to be moving downward as it slows?
