How to Normalize and Integrate a Wave Function in the Range 0 to L?
To normalize the wave function ψn(x) = A * √x * sin(nπx²/L²) in the range 0 to L, one must integrate the square of the wave function and set the result equal to one to solve for the normalization constant A. The integration involves handling the term cos((2πx²)/L²), which can be simplified by substituting variables to yield cos(y²). However, this integral does not have a solution in terms of standard elementary functions, as indicated by the use of the Fresnel C Integral. Despite this complexity, integrating the square of the original wave function can be simplified using the identity sin²(y) = (1/2)(1 - cos(y)). The discussion highlights the challenges and strategies involved in normalizing wave functions in quantum mechanics.
theblender
Pretty basic question here, but I was wondering if someone could explain to me how to normalize a wave function. Specifically:
ψn(x) = A * √x * sin (n∏x2/L2), n = 1, 2, 3, ...
Normalized in the range 0 to L.
Thanks for the help, a little bit of a walk through would be much appreciated.
What have you tried so far, and where are you stuck?
Well, I'm working it now, its been shed under some new light, so what I am doing is just integrating the square of psi and setting it equal to one, then solving for A. Which is what I tried initially, but I just got confused with multiplying the original by the complex conjugate.
Also having trouble integrating the statement cos ((2*pi*x^2)/L^2) dx.
Hint: you need to substitute x for some variable y so that you end up with cos(y^2) in the integrand. Then you can try messing around with trig, for example cos(y^2) = cos(y*y) = ?
You realize there is no easy way to expand that. In fact, wolframalpha gives:
http://www.wolframalpha.com/input/?i=cos(x^2)
which uses the "Fresnel C Integral" which I haven't even come across until this example.
So the integral is not representable by standard elementary functions...Edit: However integrating the square of your original wavefunction is quite straightforward once you calculate the integral of x(sin^2)(x^2).
Use the fact that (sin^2)(y) = (1/2)(1-cos(y))
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 31 ·
  • · Replies 19 ·
