NPN BJT in reverse active mode - base current direction
4 replies · 6K views · last reply
etf
Warning: Template missing in homework help request.
Hi!
I was wondering what happens with Base current direction if NPN BJT works in reverse active mode? In forward active and in saturation mode currents are like this:
Circuit diagram of an NPN bipolar transistor with labelled B, C and E terminals, base current i_B entering from the left, collector current i_C leaving downward at top, emitter current i_E at bottom, and voltage labels V_BE and V_CE with polarity signs.
Collector and emitter currents in reverse active mode would be in opposite direction:
Schematic of an NPN BJT with terminals B, C and E labelled, showing I_C arrow up at collector, I_E arrow up at emitter, and V_CE and V_BE voltage polarity marks.
In this case base current would be flowing from the base into the collector. So it would still be flowing into the base, but instead of flowing out of the emitter it would be flowing out of the collector.
Is it possible for base current to flow in opposite direction, like this:
Hand-drawn NPN bipolar transistor schematic with labels B, C and E, arrows showing IC and IE upward and IB leftward, and voltages VCE and VBE marked with plus and minus signs.
Here is example from Multisim:
Multisim circuit schematic of an NPN transistor 2N2222 with 12 V and 2 V DC sources, resistors R1 100 Ω and R2 100 kΩ, three multimeters U1, U2 and U3, and current probes reading -3.08 nA, -111 pA and -3.14 nA.
No. Forward active mode means the emitter/base junction is forward biased. Reverse active mode means the collector base junction is forward biased. In both cases current is flowing into the base. In order for current to flow out of the base, it has to be flowing through a reverse-biased junction. This means the junction is in breakdown, which typically destroys a bipolar transistor. Multisim may show it happening, but if you try it on a real device you will fry it.
One definitelly shouldn't trust to simulation software 100% :)
You helped me a lot, thanks!
