What is the optimal point in the nullspace of A using Lagrange multipliers?
  • Thread starter Thread starter hoffmann
    Matrix Nullspace
To find the optimal point x* in the nullspace of an m×n matrix A using Lagrange multipliers, one must express x* in terms of a given point x and matrix A, typically as x* = A*(A'A)⁻¹A'x. The significance of x* lies in its representation as the projection of x onto the nullspace of A, which is orthogonal to the row space of A. The problem can be approached by setting up an objective function with equality constraints, ensuring differentiability for Lagrange application. Geometrically, the vector from x to x* should be perpendicular to the nullspace, illustrating the shortest distance concept analogous to a line perpendicular to an axis. Understanding these relationships is crucial for solving the problem effectively.
hoffmann
Does anyone know how to approach this problem?
Let A be an m×n matrix of rank m, where m<n. Pick a point x in R^n, and let x∗ be the point in the nullspace of A closest to x. Write a formula for x∗ in terms of x and A.
What exactly is the significance of the point x* in the nullspace of A?
i think this question has something to do with the orthogonality of subspaces and is analogous to saying the shortest distance between a point and an axis is just a perpendicular line...
So, Ax* = 0 which is basically what it means by x* being in the nullspace of A. x* is a vector which multiplies A to take it to 0.
I think it has something to do with the least square solution for linear systems.
I think you should think of the solution in terms of the projection of x onto the nullspace of A, which would be x*.
This is simply given by A*(A'A)-1*A'*x. Sorry, I am not fluent with latex.
A' = transpose of A.
-1 = inverse
* = multiplication
Refer to the Strang book on least square and projection of vectors onto the column space of a a matrix.
We know that the row space is in R^{n} and that it is orthogonal to the null space.
Imagine that we have a 2x3 matrix with rank 2. It's row space would be a plane in R^{3}, and it's null space a line perpendicular to that plane. If we pick a point x in that plane, wouldn't the point closest to the null space be that same point x?
I'm eagerly awaiting someone to help us out :)
^^ i think you're on the right track, dafe.
i think an analogy to this problem is, what is the shortest distance between a point in the xy plane and the x axis. it's just a line perpendicular to the x-axis.
so in the context of the problem i asked, it's like...the dot product between the point x and...the row space? something like that...
ok, some help:
1) set this up with a variable (btw, better to call the starting point x0 rather than x, since it is fixed), an objective function and a set of equality constraints. Write them down. You should replace the objective function by something nicer: for example no square roots, since to apply Lagrange you need a differentiable function.
2) show geometrically in terms of the level sets of the objective function and the tangent space of the constraints that the vector x0 - x* is perpendicular to the null space.
3) form the Lagrangian. solve.
  • · Replies 26 ·
