Number Combinations: 30 Items in 6x5 Array
  • Topic:
  • Thread starter schinb65
    Combination
3 replies · 7K views · last reply
schinb65
Thirty items are arranged in a 6-by-5 array. Calculate the number of ways to form a set of three distinct items such that no two of the selected items are in the same row or same column.
I am told the answer is 1200.
I do not believe that I am able to use the standard combination formula.
This is what I did which I got the correct answer but do not really believe I am able to do this every time.
The first Number I can chose from 30.
The Second #, Chose from 20.
The 3rd #, Chose from 12.
So 30*20*12= 7200
7200/6= 1200
I divided by 6 since I am choosing 3 numbers and I multiplied that by 2 since I have to get rid of each row and column when a number is chosen.
Will this always work? Does an easier way exist?
I'm not sure what the correct answer is but [math]\frac{30*20*12}{\binom{3}{1}}=2400[/math] is my first thought. I don't see a reason to divide by 2 at the end. Hopefully someone else can provide some insight but that's my first thought on the problem.
Let's look at a simpler case of a 3x3 grid where we want to arrange 3 items that can't be in the same row or column. The first item has 9 slots, the second has 4 and the last one just has 1. We again divide by [math]\binom{3}{1}[/math] to account for the combinations of these items and that should be the final answer.
Anyway, that's my reasoning for now. Not promising it's correct unfortunately :(
Hello, schinb65!
This is what I did which I got the correct answer,
The first number I can chose from 30.
The second #, choose from 20.
The third #, choose from 12.
So: 30*20*12= 7200
7200/6 = 1200 . Correct!
The first can be any of the 30 items.
Select, say, #7; cross out all items in its row and column.
. . $\begin{array}{|c|c|c|c|c|} \hline
1 & \times & 3 & 4 & 5 \\ \hline
\times & \bullet & \times & \times & \times \\ \hline
11 & \times & 13 & 14 & 15 \\ \hline
16 & \times & 18 & 19 & 20 \\ \hline
21 & \times & 23 & 24 & 25 \\ \hline
26 & \times & 28 & 29 & 30 \\ \hline
\end{array}$The second can be any of the remaining 20 items.
Select, say, #24; cross out all items in its row and column.
1 & \times & 3 & \times & 5 \\ \hline
11 & \times & 13 & \times & 15 \\ \hline
16 & \times & 18 & \times & 20 \\ \hline
\times & \times & \times& \bullet & \times \\ \hline
26 & \times & 28 & \times & 30 \\ \hline
\end{array}$The third can be any of the remaining 12 items.
Select, say, #28.
1 & \times & \times & \times & 5 \\ \hline
11 & \times & \times & \times & 15 \\ \hline
16 & \times & \times & \times & 20 \\ \hline
\times & \times & \bullet & \times & \times \\ \hline
\end{array}$There are: .$30\cdot20\cdot12 \,=\,7200$ ways to select 3 items.
Since the order of the selections is not considered,
. . we divide by $3!$
Answer: .$\dfrac{7200}{3!} \;=\;1200$
That was the thing I was missing, soroban! Thank you for pointing it out. We should divide by $3!$, not [math]\binom{3}{1}[/math].
