Number of bits required for floating point representation
4 replies · 2K views · last reply
CGandC
Relevant equations ( a quote from the book A Concise Introduction to Numerical Analysis by A. C. Faul explaining what is floating point representation ):
We live in a continuous world with infinitely many real numbers. However, a computer has only a finite number of bits. This requires an approximate representation. In the past, several different representations of real numbers have been suggested, but now the most widely used by far is the floating point representation. Each floating point representations has a base ##\beta## (which is always assumed to be even) which is typically 2 (binary), 8 (octal), 10 (decimal), or 16 (hexadecimal), and a precision ##p## which is the number of digits (of base ##\beta## ) held in a floating point number. For example, if ##\beta=10## and ##p=5##, the number 0.1 is represented as ##1.0000 \times 10^{-1}##. On the other hand, if ##\beta=2## and ##p=20##, the decimal number 0.1 cannot be represented exactly but is approximately ##1.1001100110011001100 \times 2^{-4}##. We can write the representation as ##\pm d_0 . d_1 \cdots d_{p-1} \times \beta^e##, where ##d_0 . d_1 \cdots d_{p-1}## is called the significand (or mantissa) and has ##p## digits and ##e## is the exponent. If the leading digit ##d_0## is non-zero, the number is said to be normalized. More precisely ##\pm d_0 . d_1 \cdots d_{p-1} \times \beta^e## is the number
\pm\left(d_0+d_1 \beta^{-1}+d_2 \beta^{-2}+\cdots+d_{p-1} \beta^{-(p-1)}\right) \beta^e, 0 \leq d_i<\beta
__________________________________________________________________________________________________________
I've been reading A Concise Introduction to Numerical Analysis by A. C. Faul and I've been inquiring about the number of bits required to represent a number in floating point representation with base ## \beta ##, precision ## p ## and maximum and minimum exponents ## e_{\max}, e_{\min}##.
Here's the author's calculation:
The largest and smallest allowable exponents are denoted ##e_{\max }## and ##e_{\min }##, respectively. Note that ##e_{\max }## is positive, while ##e_{\min }## is negative. Thus there are ##e_{\max }-e_{\min }+1## possible exponents, the +1 standing for the zero exponent. Since there are ##\beta^p## possible significands, a floating-point number can be encoded in ##\left[\log _2\left(e_{\max }-e_{\min }+1\right)\right]+\left[\log _2\left(\beta^p\right)\right]+1## bits where the final +1 is for the sign bit.
My question: how did the author arrive to ##\left[\log _2\left(e_{\max }-e_{\min }+1\right)\right]+\left[\log _2\left(\beta^p\right)\right]+1## ?
I tried as follows but didn't succeed: the number is ##\pm d_0 \cdot d_1 \cdots d_{p-1} \times \beta^e##, each of ## d_i ## is at most ## \beta ## and since the largest exponent is ## e_{\max} ## then the largest number possible is ## \beta . \beta \cdots \beta \times \beta^{e_{\max}} ##, hence the number of bits is ( add one for plus/minus sign ) ## \lfloor log_2( { \beta^p \cdot \beta^{e_{\max}} }) \rfloor +1 = \lfloor log_2( { \beta^p}) + log_2({ \beta^{e_{\max}} }) \rfloor + 1 ##
You have neglected to take account of how the number is actually encoded.
The number [tex] (-1)^S \times d_0.d_1d_2\dots d_{p-1} \times \beta^{e_{\mathrm{min}} + (e - e_{\mathrm{min}})}[/tex] is encoded as the [itex]N_1 + N_2 + 1[/itex] digit binary integer [tex] S\;D_1D_2\dots D_{N_2}\;E_1E_2\dots E_{N_1}[/tex] where [itex]S[/itex] is the sign bit, [itex]D_1D_2 \dots D_{N_2}[/itex] is the binary representation of [itex]0 \leq d_0d_1\dots d_{p-1} \leq \beta^p - 1[/itex] and [itex]E_1 \dots E_{N_1}[/itex] is the binary representation of [itex]0 \leq e - e_{\mathrm{min}} \leq e_{\mathrm{max}} - e_{\mathrm{min}}[/itex]. The maximum integer which can be represented with [itex]N[/itex] binary digits is [tex]1 + 2 + \dots + 2^{N-1} = 2^N - 1[/tex] so we require [tex]\begin{split}<br /> N_1 &\geq \log_2(e_{\mathrm{max}} - e_{\mathrm{min}} + 1), \\<br /> N_2 &\geq \log_2(\beta^p). \end{split}[/tex] The minumum necessary numbers of binary digits are therefore [tex]\begin{split}<br /> N_1 &= \lceil \log_2(e_{\mathrm{max}} - e_{\mathrm{min}} + 1) \rceil, \\<br /> N_2 &= \lceil \log_2(\beta^p) \rceil, \end{split}[/tex] where [itex]\lceil x \rceil[/itex] is the smallest integer greater than or equal to [itex]x[/itex].
If a specific example would help, you might look up how IEEE 754 does things.
The "is at most ##\beta##" part is incorrect. Whatever the base ##\beta## is, each digit ##d_i## must be less than ##\beta##.
In base-2, the digits are 0 and 1.
In base-8, the digits are 0, 1, 2, 3, 4, 5, 6, and 7.
In decimal (base-10), the largest digit is 9.
