Number of eigenvalues of this Hermitian
The discussion revolves around a problem from quantum mechanics concerning the eigenvalues of a Hermitian matrix related to angular momentum and angular velocity. The original poster attempts to demonstrate that the matrix M has three eigenvalues, which would imply that there are three directions where angular momentum and angular velocity are parallel.
  • Participants discuss the properties of the Hermitian matrix M, including the nature of its eigenvalues and the implications of having distinct versus repeated eigenvalues. The original poster considers using the diagonal elements or the trace of M to count eigenvalues. Others question the necessity of distinct eigenvalues and suggest that the existence of three directions may hold regardless of the uniqueness of the eigenvalues.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the implications of the spectral theorem for Hermitian matrices and the nature of eigenvalues in this context. There is no explicit consensus yet on the reasoning or the approach to take.
Participants note that the problem involves a physical interpretation of angular momentum and angular velocity in a rotating system, and there are considerations regarding the implications of having zero eigenvalues. The original poster's reasoning is based on the assumption that M is a moment of inertia tensor defined in three-dimensional space.
kuchenvater
Hi. I'm trying to study QM from Shankar on my own. Asking this here because I don't really have a teacher to help me with this:
I'm trying to solve problem 1.8.9 -part 3 of "The Principles of Quantum Mechanics" by R Shankar. Here's the problem:
Given the values of Mij (see next section for equations) which is Hermitian, argue that there exist three directions such that the angular velocity and angular momentum will be parallel.
Given
Mij=∑a=ma[ r2a δij - (ra)i(ra)j ]
here i denotes the ith Cartesian component.
|l>=M|ω>
It's known that M is Hermitian. l and ω will be parallel if ω is an eigenvector of l. So I have to prove that the number of eigenvalues of M is 3. Somehow I can't figure out a way to do that. It's obvious that all eigenvalues will be real and the number of eigenvalues is equal to or less than the rank of a matrix. I was thinking I could consider only the diagonal elements of a diagonalized version of M or just the trace of M(which yields the sum of all eigenvalues) by setting i=j and then I'd have i as the index of sigma. If I can count the number of values of i, I'd have the number of eigenvalues. And since M is Hermitian and has real eigenvalues and this describes a rotating system of mass(i.e. it's moment of inertia), it must be defined in the real plane and that has 3 axes-x,y and z, one for each value of i. So i varies across 3 values, hence the diagonalized matrix has 3 diagonal elements and hence 3 eigenvalues. The question also mentions the mass's cartesian component, so that automatically means x, y, z.
Is that correct reasoning?
That would be correct if you prove that your matrix M has three distinct eigenvalues. That is not always the case. Consider a set of 8 masses placed on the corners of a cube, with origin at the center of the cube. The moment of inertia tensor M for this is a diagonal matrix with all diagonal elements equal to one another. There's only one eigenvalue.
What you need to show is that one can always at least three directions along which angular velocity and angular momentum are parallel, regardless of the number of unique eigenvalues.
Aside: A eigenvalue of zero is a bit problematic. This means zero angular momentum for rotation along that eigenvector. You'd have to interpret the zero vector as being parallel to all vectors.
Any hints on how to do that?
The matrix is Hermitian. What does the spectral theorem say about the eigenvectors?
