Number revolutions with constant angular decelleration
The discussion focuses on calculating the number of revolutions a bicycle wheel makes while stopping under constant angular deceleration. The wheel, initially rotating at 120 rpm, takes 65 seconds to stop, resulting in an angular deceleration of -0.1934 rad/s². Using kinematic equations, the total angular displacement during this time is calculated to be approximately 408.49 radians, which translates to about 65.01 revolutions. Participants clarify the use of angular acceleration formulas and differentiate between angular and centripetal acceleration. The conversation emphasizes the correct application of kinematic equations for angular motion.
Linus Pauling
# revolutions with constant angular decelleration
1. A well-lubricated bicycle wheel spins a long time before stopping. Suppose a wheel initially rotating at 120 rpm takes 65 s to stop.
If the angular acceleration is constant, how many revolutions does the wheel make while stopping?
2. a = omega^2*r
3. I already know the solution is theta = 65 revolutions. What is the calculation?
ok so:
120rpm = 12.57rad/s << obtained by dimensional analysis 'cause you know 1 rev = 2(pie)rads
12.57 rad/s is your initial omega
your final omega = 0 rad/s
using the kinematics equation : omega final = omega initial + alpha (delta time)
you get : 0 = 12.57 + (alpha)(65s)
-0.1934rad/s^2 = alpha << angular deceleration
so, using another kinematics equation, the one with the angular displacement:
final position = initial position + 12.57(65) + (0.5)(-0.1934)(65^2)
then you get 408.4925 rads
as a result, (use the dimensional analysis again) to get the revolutions! which is 65.01 revolutions.
i hope that helped. i might be a tad confusing :S
I understand the first part, and the reasoning used in the second, but I don't understand this part:
you know the kinematics formula : omega final = omega initial + (alpha)(time) ?
it's the same as
final angular velocity = initial angular velocity + (angular acceleration)(time)
since you have the final angular velocity and the initial, and the time, you can figure out the angular acceleration. :)
and ... why use : a = omega^2*r?
that formula is for the centripedal acceleration, and NOT the angular acceleration. centripedal is a linear acceleration! :)
  • · Replies 32 ·
  • · Replies 19 ·
