Number revolutions with constant angular decelleration
3 replies · 9K views
Linus Pauling
# revolutions with constant angular decelleration
1. A well-lubricated bicycle wheel spins a long time before stopping. Suppose a wheel initially rotating at 120 rpm takes 65 s to stop.
If the angular acceleration is constant, how many revolutions does the wheel make while stopping?
2. a = omega^2*r
3. I already know the solution is theta = 65 revolutions. What is the calculation?
ok so:
120rpm = 12.57rad/s << obtained by dimensional analysis 'cause you know 1 rev = 2(pie)rads
12.57 rad/s is your initial omega
your final omega = 0 rad/s
using the kinematics equation : omega final = omega initial + alpha (delta time)
you get : 0 = 12.57 + (alpha)(65s)
-0.1934rad/s^2 = alpha << angular deceleration
so, using another kinematics equation, the one with the angular displacement:
final position = initial position + 12.57(65) + (0.5)(-0.1934)(65^2)
then you get 408.4925 rads
as a result, (use the dimensional analysis again) to get the revolutions! which is 65.01 revolutions.
i hope that helped. i might be a tad confusing :S
I understand the first part, and the reasoning used in the second, but I don't understand this part:
you know the kinematics formula : omega final = omega initial + (alpha)(time) ?
it's the same as
final angular velocity = initial angular velocity + (angular acceleration)(time)
since you have the final angular velocity and the initial, and the time, you can figure out the angular acceleration. :)
and ... why use : a = omega^2*r?
that formula is for the centripedal acceleration, and NOT the angular acceleration. centripedal is a linear acceleration! :)
