Number theory: finding integer solution to an equation
22 replies · 5K views · last reply
mtayab1994
(E): x^2+y^2=6+2xy+3x
[tex]x^{2}+y^{2}=6+2xy+3x\Longleftrightarrow x^{2}-2xy-3x+y^{2}=6\Longleftrightarrow x^{2}+x(-2y-3)+y^{2}=6[/tex]
Any further help to find the answer??
Joffan said:
You might try looking at ##x^2 - 2xy+y^2=6+3x##
That's [tex](x-y)^{2}-3x=6[/tex]
Or ##(x-y)^2=3(x+2)## - which should be more interesting.
Can we use substitution and say that x+2=n?
Sure, although we will find a better substitution... what can you tell me about ##n##?
On the question before I proved that x^2 Ξ 0(mod3) and that means that x^2=3n.
Hmm, not really. Let's define ##m:=(x-y)## - what can you tell me about ##m##?
That means that m is the difference of x and y.
My question is, what does ##m^2=3n## (using the new definitions) tell you about ##m##?
That means that m^2 is divisible by 3 hence divisible by all multiples of 3.
Is that what you meant to say? 81 is divisible by 3, but it's not divisible by 6, which is a multiple of 3.
Yes... what does that mean for ##m##?
mtayab1994 said:
... hence divisible by all multiples of 3.
What? No. For example, 36 is divisible by 3 but not by 15.
If we said that m=x-y then m^2=(x-y)^2=3n .
So then we get that (x-y)^2=3n right?
Yes, but it doesn't follow that m2 is divisible by all multiples of 3, which is what you claimed.
But how are we supposed to find integer solutions out of that? I found that y=n^2-3n-2 and that's wrong I think.
At this point, you're going to have to think about it a bit on your own. You've got all the pieces. You just need that last little insight, which is what Joffan's been trying to get you to see.
Which new definitions m=x-y?
Don't backtrack. We have defined new variables ##m## and ##n##; the formula translates into those variables as shown; now you need to understand what ##m^2=3n## tells you about ##m##.
Well there are 3 cases:
Case 1: if m Ξ 0(mod3) then m^2 Ξ 0(mod3)
Case 2: if m Ξ 1(mod3) then m^2 Ξ 1(mod3)
Case 3: if m Ξ 2(mod3) then m^2 Ξ 4(mod3) with is m^2 Ξ 1(mod3)
So that means that m^2=3n . So that means the when m is divided by 3 you get either a remainder of 0,1, or 2 am i right?
Looks good.
How did you come up with that conclusion based on what you wrote above?
What is the value of ##3n## mod 3?
3n mod 3 means that 3n=3k so that means 3k equals the multiples of 3 which are 3n.
