Number Theory: nth root of n is irrational
The discussion revolves around the assertion that for n ≥ 2, the nth root of n, denoted as n^(1/n), is irrational. Participants are exploring the implications of this statement within the context of number theory, particularly focusing on properties of prime factors and coprimality.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to use a proof by contradiction, questioning the implications of assuming n^(1/n) is rational. They discuss the relationship between prime factors of n and the integers a and b in the expression n = a^n/b^n.
The discussion is active, with participants providing guidance on considering the prime factorization of n and the implications of gcd(a, b) being 1. There is an ongoing exploration of the validity of certain steps in the proof and whether specific theorems are required to support their reasoning.
Participants note the importance of understanding the relationship between the number of prime factors of n and the implications for the rationality of n^(1/n). There is also a recognition of the need to clarify certain mathematical properties, such as the behavior of gcd under exponentiation.
barylwires
1. For n ≥2, n^(1/n) is irrational.
Hint provided: Use the fact that 2^n > n2. This is probably familiar to many.
By contradiction, n = a^n/b^n
--> a^n = n(b^n)
--> n|a^n
--> n|a
Am I trying to force the same contradiction as with 2^1/2 is rational, that is, that a/b are not in lowest terms? Or do I need prime factorization to do something? Guidance is appreciated.
The fact that 2^n > n means that n cannot have n or more prime factors. Supposing that a and b are coprime also helps.
I don't think I'm using the hint in the following way; is it correct?
n=a^n/b^n --> a^n=n•b^n --> b^n|a^n --> b|a --> n^(1/n) is an integer,
but by hyp., n≥ 2 --> 2^(1/2) is an integer --><-- (relies, of course, on sqrt(2) known to be irrational)
That's not quite a contradiction. You've assumed the statement is true in the subcase that [tex]n \ge 3[/tex], in which the statement "2^(1/2) is an integer" has no effect.
Maybe go up to a^n=n•b^n, and look at primes dividing n on the RHS.
Why are primes dividing n on the RHS? Do you mean I should consider the division of n by primes? As is , the problem implies two divisions: n|a^n and b^n|a^n.
I mean that you should consider division of n by primes, yes.
I see that n has r<n prime factors, and that n|a^n.
And a^n/n = b^n.
I can't see the connection between this feature, the fact that a and b are co-prime, and a contradiction.
And a^n/n = b^n.
There is no way that (a/b)^n with a/b in lowest terms can be an integer unless b=1. Can you show that?
Thanks.
My initial contradictory supposition was that n^(1/n) was rational. My biggest problem here (I think) is seeing where rational a/b must be integer a/1. Is that what the hint is supposed to help me see? That no integer x can have x or more factors, together with gcd(a, b)= gcd(a^n, b^n) = 1. ?
barylwires said:
Thanks.
If (a/b)^n=n and a/b is in lowest terms, and b is not 1, then there is a prime p that divides b but not a. So you can write b=pc. So a^n=(pc)^n*n. Conclusion? It's really just like the sqrt(2) is irrational proof.
Many thanks for all the good pushing. What I have is clunky at best, and probably flawed:
n = (a/b)^n
[tex]\Rightarrow[/tex]b^n|a^n
[tex]\Rightarrow[/tex]gcd(a^n, b^n) = b^n = gcd(a, b) = 1
[tex]\Rightarrow[/tex]b=1
[tex]\Rightarrow[/tex]n=a^n.
Since n≥2, a>1, but
n≤2^n
[tex]\Rightarrow\Leftarrow[/tex]
n = (a/b)^n
Since n≥2, a>1, but
n≤2^n
Keep most of that proof. But it's not generally true that gcd(a^n,b^n)=gcd(a,b), right? gcd(a^n,b^n)=gcd(a,b)^n. Do you have that theorem already proved? If so then it's fine. Otherwise you have to prove it. Or you could prove if gcd(a,b)=1 then gcd(a^n,b^n)=1. Either way there is a step in the proof that you don't state a reason for, so I'm not sure how you are filling it in.
Groan. Must have been thinking a^n|b^n [tex]\Rightarrow[/tex]a|b, but writing something entirely different. I suppose sleep is everything they say it is.
a^n|b^n does imply a|b. And nothing you said is wrong. I'm just asking if you have to prove it. Or is that already a proven theorem, so you can just use it?
I should have written that, by hyp., gcd(a, b)=1 [tex]\Rightarrow[/tex] gcd(a^n, b^n) = 1, then gcd(a^n, b^n) = b^n = 1. Does that do it? I'm referring specifically to these, particular, relatively prime a and b. Clearly, gcd(4^2, 6^2) = 4 ≠ 2 = gcd(4, 6) is a counter example of gcd(a^n, b^n) = gcd (a, b), in general, right?
It sure is. You are saying nothing but true statements. I'm just asking which of them you have a theorem to back up, and which you might have to find a proof for. If you already know gcd(a,b)=1 => gcd(a^n,b^n)=1 then you are home free.
  • · Replies 22 ·
  • · Replies 36 ·
9K
