Numerical calculation about curve length
5 replies · 9K views
xyz3003
I think I have returned all my math back to teachers without any refund.
y=f(x);
h=xb-xa, which is very small.
My Q is to calculate curve length rather than area numerically.
But let me use area as example to show you what i want.
to calculate area between xa to xb, we have 2 ways:
1) area=(f(xa)+f(xb))*h/2; (trapezoid?)
2) area=(f(xa)+4*f(xm)+f(xb))*h/6; here xm=(xa+xb)/2; (parabola?)
As my test, second one is much better than first.
for curve length:
1) len=square root( (f(xb)-f(xa))*(f(xb)-f(xa)) + h*h);
actually, it is distance from (xa, f(xa)) to (xb, f(xb)).
do you know second way to calculate curve length as in area sample above, simple, easy-to-use and better?
any links or explanations are highly appreciated.
thanks.
Well, in regions where the curvature is slowly varying, you might interpolate with circular arc segments instead.
Just a suggestion..
Start from an integral representing the length of the curve
[tex]\int_{x_1}^{x_2} \sqrt{1 + \left(\frac{dy}{dx}\right)^2}\,dx[/tex]
or [tex]\int_{t_1}^{t_2} \sqrt{\left(\frac{dx}{dt}\right)^2 + \left(\frac{dy}{dt}\right)^2\right)}\,dt[/tex] for a curve defined by parametric equations.
Evaluate the integrals with your favorite numerical formula.
I just want to know the "favorite numerical formula", if which is better than summing line distances from one point to another.
As I said before, in most cases, Simpson's rule is most efficient.
I like the trapezoidal rule because it does a good enough job for most things and is much less tedious than simpons.
