Numerical integration of discrete data
3 replies · 9K views
hermano
Hi,
I'm searching for days for a numerical integration methode for discrete data given at non-equidistant nodes. The simple Simpson rule can only be used for equidistant nodes so I'm looking for methode which I can solve my problem. Any suggestion is welcome!
Thanks in advance!
As far as i know, for discrete data, i can probably utilize the Lagrange's Interpolation or Newton's Interpolation to generate a continuous function. Then, the next step, i think i can calculate the integral using simple Simpson rule or other methods for numerical calculation.
Maybe the INTERPOLATION can be helpful for you!
hermano said:
Hi,
Thanks in advance!
Do all of the have points have "random" spacing or are the spacings mostly the same with just a few uneven spaced ones?
In any case the trapezoidal rule would be trivial to adapt to uneven spacing, if that was sufficiently accurate.
I think I could adapt simpsons rule to uneven spacing if I put my mind to it (which usually means someone has already done it), but it wouldn't be a trivial problem like with the trapezoidal rule.
hermano:
The attached file derives the general coefficients for Simpson's First Rule. This is the usual 1-4-1 rule when the ordinates are equally spaced. The derivation contained in the attachment assumes that one is trying to integrate the curve passing thru the points (x0, y0), (x1, y1), and (x2, y2). The integral is evaluated thus: A = k0 * y0 + k1 * y1 + k2 * y2
The coefficients k0, k1, and k2 for unevenly spaced ordinates are given on p.32 of the attachment.
