NVidia Geforce 8800 GTS 320MB Superclocked
  • Thread starter Thread starter |)a\/1d
    Nvidia
14 replies · 5K views
|)a\/1d
Should i get the nVidia Geforce 8800 GTS 320MB Superclocked, its $300 and the video performance is very good and its already factory overclocked with a lifetime warrenty. Does anyone have it cause I'm open to comments and stuff.
i used to be a video card addict, i don't think it's worth it. education first! unless you're already past that.
russ_watters said:
What kind of games do you play?
ahh just Warcraft 3 and some other games like u know ocassional CS and other games, Halo, Halo 2 and Halo 3 when it comes out, my OS is vista ultimate so i need a good video card for the Aero features and stuff.
I got a 7600 GT and it handles the graphics for all of the games fine on high for every setting. Are you hooking up to a LCD tv or a monitor?
What's it currently clocked at? I've heard you can typically increase the core of the 8800 GTS from the std 500MHz to 640MHz and the memory from 1600MHz to 1800MHz which would bring it's performance on a par with the much more costly 8800 GTX!
Only problem is it's a little more difficult to overclock Nvidia cards these days as their latest drivers don't support Coolbits.
You have got that right! I tried to overclock my video card and it just failed to boot correctly every time after I increaced the core clock.
i know it can almost beat the nvidia 8800 GTX, right now its 575 for core and 1700 for memory. Is that good? its the superclocked edition too, so if it overheats i can get a free refund for lifetime. :)
I love nVidia cards I have never had a problem with any of their products. Some people apparently have a lot of DOA products from them but I have never had the problem. It sounds like a good card if you are just going to be running CS and WOW. I don't think you need to go crazy into the $1,000 cards.
I currently have a standard 8800GTX and had an 8800GTS before that. You simply cannot beat the performance... hands down. The thing that it really comes down to is what resolutions you plan on running at. The 8800's really shine when you run really high resolutions along with anisotropic filtering and anti-aliasing fully cranked. If you mainly run mid-level resolutions (1024x768-1280x1024 as an example) i would save the money and go with an 8600 series. If you still feel as though there is not enough performance... drop in another one and run in SLI. You'd also still have less money invested as opposed to going outright with a GTS.
The main reason i went with a GTX is because i have a 22" widescreen monitor (1440x1050) that I play everything on. I also wanted to be able to fully max out A-filtering and AA without any hiccups. The DX10 support was also a big player. At the same time though I bought my GTX in December of '06 before the lower and mid-level cards came out.
my monitor is 1680x1050 so is that good? like would the 8800GTS be good for 1680x1050?
I'd also be wary of overclocking the cards without water cooling. My GTS card bit the dust shortly after upping the frequency to 600mhz. Thankfully the companies have a lengthy manufacturers warranty.
I do have to add though that an overclocked GTS still doesn't come close to the performance level of a GTX. The GTS has two less shader cores (6 vs 8), 96 vs 128 stream processors, a 320 vs 384 bit memory interface and less pixel pipes (can't remember the exact numbers).
The GTS still ain't no slouch though!
now that's some resolution. If I were you i'd go with the GTS. You'd also still have the option of going SLI if your motherboard supports it. I loved the GTS though. Honestly here was only a handful of instances where I noticed a considerable difference (if any at all) between the GTX and GTS... mostly in various benchmarks. When the next level of games start coming out (DX10 support becomes a temporary standard) the differences may start to become obvious. The memory bottleneck is still an issue though.
