Undergrad Object in or out of a circular field of view? (celestial coordinate system)
In celestial coordinate systems, determining if an object with right ascension (RA) and declination (dec) is within a circular field of view of radius R requires a specific calculation. For small angular separations, the angular distance should be computed using the formula sqrt(δdec^2 + cos^2(dec)*δRA^2), rather than a simple Cartesian distance. This is important because the change in RA varies with declination, especially near the poles. The discussion also references a resource for further understanding of the formula and its derivation. Accurate calculations are essential for precise celestial navigation and observation.
vladivostok
TL;DR
Check that object with position RA and dec is within circle of radius R (in arcminute) ?
In celestial coordinate system (right ascension/declination), how to check if an object with position RA and dec is within a given circular field of view of radius R (in arcminutes) and centred at (0,0)?
R is small in this case so I assumed that I could compute the distance d of the object from the center as in cartesian coordinates: d = (RA^2+dec^2)^0.5 and check that d is less than R. Is that correct (at least for small angular separation) ?
Thanks !
Astronomy news on Phys.org
vladivostok said:
Summary:: Check that object with position RA and dec is within circle of radius R (in arcminute) ?
Thanks !
Not really. A change δdec is the same size everywhere, but a change δRA gets smaller as you get nearer the poles. So for small changes, the angular separation between two objects is give by sqrt(δdec^2 + cos^2(dec)*δRA^2). Of course this won't make much difference if you are at (0,0), which is on the equator.
Thanks a lot and sorry for the late reply. Do you have any reference for the formula that you give? I'd like to see how it is derived.
Thanks again.
Thanks again.
Here's a good link. The formula I gave is down near the bottom of the page. It also has more general formulae for when the differences of the coordinates are not small.
http://spiff.rit.edu/classes/phys373/lectures/radec/radec.html
Likes vladivostok
Great, thanks !
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 142 ·
133K
  • · Replies 16 ·
